help , fuel pack
Old May 15, 2012 | 06:32 AM
Gman in NC's Avatar
Gman in NC
FuelMoto did my set-up for me. Plug and Play.
Old May 15, 2012 | 07:13 AM
jeffreydsilver's Avatar
jeffreydsilver
Default My V&H Experience
Originally Posted by cop242
THE only change i have made is I installed a set uf Bub Rinehart 2-2 pipes and a Screeming eagle air filter. I don't plan on doing motor work, thanks for your help
Go to the V&H web site and plug in your bike and the mods made on it to see if they have a recommended fuelpak setup for it. If you are not experiencing any problems with the bike and fuel mileage has remained consistant you may not need any management product! I put a set of slipons on my RK and experienced excessive decel popping (a sign of running to lean). The V&H website didn't have a recommended setting for my bike and what I had done, so I contacted them direct and they gave me a suggested setup. Once I installed the fuelpak, no more decel popping and the bike ran great.
I wouldn't recommend the fuelpak for anything more than the basic muffler / air filter change. Beyond those mods you will definately want a more advanced fuel management setup!
Old May 15, 2012 | 07:37 AM
Leech1107's Avatar
Leech1107
If you are not doing any other work then you are ok with the fuel pak. Find a used one that will work for your bike and get a better deal. I have a fatcat and heavy breather and a FP works good the performance i felt was from the pipe. The only thing IMO that the FP did was limit the deccel pop.
Old May 15, 2012 | 07:40 AM
suiii15's Avatar
suiii15
+1 on PCIII
sgr60
Nov 20, 2013 12:46 AM
gdanny
Jan 30, 2012 01:58 PM
Nemo09
Aug 15, 2010 01:32 AM
lyonm56
Mar 10, 2007 12:19 PM
sedbiker62
Feb 22, 2006 12:02 PM
