Send help please, chrome switch housing install problem!!
Old Jan 24, 2013 | 10:41 PM
soft 02's Avatar
soft 02
Can you get a flat screwdriver blade between the ferrel shoulder and the housing and pry it off or a small punch on the inside and tap it out.
Old Jan 24, 2013 | 10:47 PM
cruzomatic's Avatar
cruzomatic
Yeah, I tried the screwdriver pry off attempt and it just damaged it more. I also tried pounding it out, but with not a punch. Lemme try that now.
Old Jan 24, 2013 | 10:49 PM
soft 02's Avatar
soft 02
First question. does it rotate. Second. did you get the retaining clip out?
Old Jan 24, 2013 | 11:00 PM
cruzomatic's Avatar
cruzomatic
Soft 02...
HAHAHA!!!! Geezzz man. I got it. I used a vise grip holder, pinned it down on my work bench and used a punch and a rubber mallet...BAM!!!!! and out it came.
yes, it was rotating and no I couldn't get the clip out. Didn't get it out on the first one. Nevertheless...got it. Thanks bro..
Old Jan 24, 2013 | 11:02 PM
cruzomatic's Avatar
cruzomatic
Now, tomorrow, when trying to put it all back together. I'll forget how it all came apart and will be posting this in the reverse order.....HA.
Thanks....
Old Jan 24, 2013 | 11:04 PM
soft 02's Avatar
soft 02
No problem. Fixin problems is my gig. You gunna need to re crimp the cable that popped out of the thingy. Take a center punch and punch the sleeve when your all done.
Old Jan 24, 2013 | 11:05 PM
cruzomatic's Avatar
cruzomatic
Ok, will do. Thanks....I appreciate the help.
Old Jan 25, 2013 | 05:18 PM
kennygsuperglide's Avatar
kennygsuperglide
sorry to see that, brother. That's why the snap rings should be removed. Might be able to slide it back together. I dunno'. good luck.
Old Jan 26, 2013 | 04:43 AM
hawnd83's Avatar
hawnd83
These should be fairly simple to pop in and out. I've had throttle cables on and off harleys umpteen million times and never had a problem like this. They are just quick disconnect retainer rings, they shouldn't need removed to disconnect or reconnect the cables. Maybe there was some dirt n such keeping it from collapsing. A good tip is to also pull as close to the housing as you can to keep that crimped part from coming apart like yours did. twisting it around as you pull/push helps too.
Old Jul 12, 2015 | 01:52 AM
geeman6181's Avatar
geeman6181
6th Gear
Default Throttle Cable Removal
I used a small pin punch and a 2x4. The return cable clip was fine but the other I made a new clip out of a piece of a spring. It worked awesome.
bobby5
Jun 21, 2017 12:27 PM
Stew Pidaso
2014-2024 Touring Models
Mar 22, 2015 01:35 PM
Govno
Feb 20, 2012 08:59 PM
HDF Tech
Nov 29, 2008 07:12 AM
krub6t9
Apr 11, 2008 10:07 PM
