Shotgun Install (just one issue)
Old Jul 22, 2013 | 03:34 PM
KumaRide's Avatar
KumaRide
Just installed one and same challenge. Used a wooden stick to persuade/push the compressor to go fully against the oil drain hose, then the shock could be lifted into place. When all said and done, compressor is touching trans, their is about ~3/16" clearance between shocks and compressor. No clearance between compressor and drain hose but this should not be an issue as it is the compressor body touching, not the compressor fins as they get hot. Bent the brake line a bit and secured some stock harnesses to the brake line that could possibly lay on the compressor fins. Prefer a tight fit with a larger compressor!! All is good!!
Old Jul 22, 2013 | 03:50 PM
J.D.1's Avatar
J.D.1
Former Sponsor
Default Appreciate that
Originally Posted by Benway
It's all good JD. I turned wrenches on aircraft for 20 years, so I'm not above a little tweaking here and there. I will say, asside from that, The whole kit and build is so good that you almost don't need instructions. A+
Love the shocks!
Been a while since I got an A+
Old Jul 23, 2013 | 09:12 AM
Benway's Avatar
Benway
I'm with you, I prefer the larger compressor, but I did not want that pressure against the drain tube, so I opted to file the corner of the pump down. Still, gotta hand it to JD for engineering this whole thing.
Old Jul 24, 2013 | 10:00 AM
casbar's Avatar
casbar
When did the new compressor become part of the kit then? I fitted my Shotguns in January, bought the kit from JD in December. Fitted to an 07 Heritage, and I didn't experience any issues fitting at all ??? Have I been lucky, or do I have a smaller compressor :-)
Old Jul 24, 2013 | 12:11 PM
Benway's Avatar
Benway
Pictures of the old compressor are on the shotgun site. It's just a tad shorter (maybe a 1/4").
Old Jul 24, 2013 | 02:52 PM
casbar's Avatar
casbar
Only pics I could see was in the installation guide. So when did the compressor model change?
Old Jul 24, 2013 | 04:50 PM
senzard's Avatar
senzard
Looks the biz...thats nice
jag40oz
Engine Mechanical Topics
Mar 31, 2016 06:32 AM
PANHEADMCC
Oil Archive (no new posts)
Jan 1, 2012 02:43 PM
05ROADGLIDE
Feb 21, 2011 06:38 PM
PANHEADMCC
Panhead
13
Aug 22, 2008 11:59 AM
hotrod351
EVO
Apr 26, 2008 05:16 PM
