Primary chain/drive line on Deuce
Old Oct 28, 2013 | 10:44 AM
Subduedracer's Avatar
Subduedracer
I made the adjustment. I believe that I have it tighten to the correct specs. I still have a little slack in the drive line somewhere as I can fill it when I go from light load with no throttle to giving throttle to move it has some gap feeling before it move the bike.
Anyone have any suggestions?
Old Oct 28, 2013 | 02:25 PM
Rodzilla6's Avatar
Rodzilla6
Be careful, if it's too tight some folks say it puts too much pressure on the bearing...
Old Oct 28, 2013 | 04:42 PM
Warp Factor's Avatar
Warp Factor
Hmmm, how much slack do you suppose there is in a brand spankin' new transmission?
Old Oct 29, 2013 | 10:44 AM
Subduedracer
It wasn't doing before they put the new tire on.
Old Nov 6, 2013 | 01:05 PM
Subduedracer
I took it to the local HD dealer. They say it's normal but it wasn't doing it before I had the tire changed. I really am getting to a point where I done. It really seems hard to find a good shop with a knowledgeable tech that can diagnose issues and not just replace parts.
Old Nov 6, 2013 | 04:02 PM
Warp Factor
Beyond failing to adjust the final drive belt properly, it's hard to think of anything about a tire change which would increase driveline slack. So don't be too hard on 'em until you know more about what's going on. It might even be you, in a heightened state of awareness after a known change, as opposed to a real change.
Old Nov 7, 2013 | 01:06 PM
Subduedracer
Maybe so. Maybe I'm just getting old and expect something from the bike it is not going to do. I rode a new Diavel and that thing was tight and precise. Might be that.
Old Nov 7, 2013 | 05:53 PM
njmasterplumber's Avatar
njmasterplumber
6th Gear
Not just some folks, the factory. 1" deflection in the rear belt is fine and 5/8 on the primary chain in the minimum you want. Check your ball and ramp system. Sounds like there might be an issue there
Old Nov 7, 2013 | 08:53 PM
Jim Kraft's Avatar
Jim Kraft
My manual says 3/8" to 1/2" with 10 pounds of pressure on the upper strand at the mid point. I would think that 1" would be way to much, but maybe the Deuce is different than my old 99 Softail Custom.
Old Nov 9, 2013 | 02:38 PM
oct1949's Avatar
oct1949
46k on our 07 and we not had a single issue with the comp.,prim adj, or cam tennsioners.
1harleyman
Nov 8, 2020 09:11 PM
imboden
Aug 23, 2014 08:21 PM
foxbrow
Apr 9, 2014 07:31 PM
cgmartine
Apr 21, 2013 08:54 PM
eksofttail
Sep 30, 2010 05:09 PM
