Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Mar 22, 2015 | 05:04 PM
  #2241
Pigbacon's Avatar
Pigbacon
Originally Posted by cdonis
Thanks, i guess its the heads bringing the tq to the left. Still earlier than most any i ve seen anywhere including on( a ) motors. I cant remember where you hit the 100 tq, was it that early with the heads.
Mine was just under 100 @ 2800. Hit 100 about mid 3’s. I think the pipes had something to do with that.
Old Mar 22, 2015 | 05:16 PM
  #2242
cdonis's Avatar
cdonis
hmm, that kind of surprises me even with those pipes. Hey bud were all waitin for the paint pics.
Old Mar 22, 2015 | 06:51 PM
  #2243
oifcmb24's Avatar
oifcmb24
6th Gear
The cam is an Andrews 57h. Had the heads ported and polished while the engine was apart for some warranty work. They shaved the heads a little just to bring the compression back to stock at this altitude. I wasn't trying to take up the front tire by any means.
Old Mar 22, 2015 | 07:11 PM
  #2244
Pigbacon's Avatar
Pigbacon
You're not the only one. I am so excited and can't stand the anticipation!
There's a dyno close to me, I thought about re running my bike. DJL says the one I was on is stingy.
Old Mar 22, 2015 | 07:23 PM
  #2245
cdonis's Avatar
cdonis
And i would agree..just sayin maybe the tune, maybe the pipes or a combo of both.
Old Mar 22, 2015 | 07:28 PM
  #2246
Pigbacon's Avatar
Pigbacon
I doubt I retune tho. Mike is supposed to be one of the best.
Old Mar 22, 2015 | 08:28 PM
  #2247
cdonis's Avatar
cdonis
Oh ya i forgot who put the tune in it. Highly respected in the profession.
Old Mar 23, 2015 | 10:49 PM
  #2248
donnathedoc's Avatar
donnathedoc
Originally Posted by LucidBrkout
Donns, I just had this problem with my 2015 BO. I had to take it back to the dealer for them to take off. They replaced my cap with a new one.
I tried and tried. No budge. They used a rubber grip like youd use to open a jar sealed supper tight.
thanks!!
Old Mar 23, 2015 | 10:54 PM
  #2249
donnathedoc
Thanks Jim and everyone for your responses. We got the cap off, then ran down to the HD and bought a new one. So far, no issues with the new one. Tony was home on leave for a week, he and I got to ride together during bike week. He's now back at Osan AFB, thanks to everyone, I've passed on your positive remarks to him and he says "thanks for YOUR service", he appreciates all of you.
Old Mar 24, 2015 | 01:01 AM
  #2250
LA_Dog's Avatar
LA_Dog
Originally Posted by oifcmb24
So got my bike back yesterday. Not quite as high of numbers as I was hoping for but it's still pretty damn impressive. Seat of the pants tell the story and when the front tire comes off the ground in 3rd, you know there is a difference. This cam is amazing. Idles pretty smooth without much lope, and instant power. 100 ft lbs of torque straight from idle. I love it.
Bravo- That is exactly what a good chart should look like. You have the TQ off like a bomb from the get go, then as RPM's increase the HP builds to continue the thrill ride.
The cam selection was A+ - but, it is not just the cam here making all the magic- it is all about how the heads, ports, quench, etc were set up to be optimal for this cam. Dropping this cam in a stock motor without doing anything else would not yield the same results. You can get this type of chart with other similar cams as long as the motor is optimal for that particular cam. In short if you want this type of dyno result, you have to build the motor for the cam. The cam grind can only tell you what it is capable of doing if everything else is built to make the most of it.
[EDIT]Oh wait -crap- you had the blow up and repair (sorry - forgot) - so it sounds to me like you got damn lucky, they must have given you a bit more compression than "just bringing it to stock levels", maybe cleaned up the chamber bowls and unshrouded the valves? Otherwise you would not have those numbers. Damn good way to come out of it!
If you can, find out what your static compression is. What type of pipe you running? This will be helpful for anyone else with a fairly stock BO and considering the 57H cam.
