Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old May 2, 2015 | 03:07 PM
  #2651
brianp25's Avatar
brianp25
latest pics I'm behind, there's some awesome rides here, but ill get there.. is everyone powder coating the fender struts?
Old May 2, 2015 | 03:42 PM
  #2652
jtaliani's Avatar
jtaliani
Originally Posted by NSR
His website says his fans won't fit Breakouts. Does he have a solution that's not on the site yet?
If you can make this solution work, it did have a big impact. My temperature on the ride today stayed no less than 20-30° cooler in all riding conditions. Through town was a considerably bigger difference than that. My peak temperature for today was 234° and that was including through town, prolonged idle, and a slightly warmer ambient temperature than it's been. Cruising on back roads, my temperature stayed stable between 215-225°. The bike also cooled much more quickly. Using the thermostat, the temperature dropped from ~225° to below 150° in the time it took me to pump gas.
Old May 2, 2015 | 04:14 PM
  #2653
azrchrd's Avatar
azrchrd
This is stock..
Last edited by azrchrd; May 2, 2015 at 04:14 PM. Reason: finished.... A.MAZ.ING!!!!
Old May 2, 2015 | 04:18 PM
  #2654
azrchrd's Avatar
azrchrd
Only took an hour. Everything works fine, just make sure you cut all the zip-ties to readjust. The brake line looks like its bottomed out, but there is a little play even when the bars are maxed out to the left. I put new zip-ties on to clean everything up and re-checked all clearances. Lastly, took it for a ride, best thing I could have done to keep the OEM bars!
Old May 2, 2015 | 04:22 PM
  #2655
sincitychoppa's Avatar
sincitychoppa
That looks sweet. I just ordered a set of 1.5" chrome risers as well. I can't wait to bolt them on.
Can you give detail on how the ride improved?
Old May 2, 2015 | 04:26 PM
  #2656
azrchrd's Avatar
azrchrd
Absolutely! First thing I noticed was the reach, I actually sit more upright now, and my arms are bent at the elbow, instead of locked out, so I'm in a much more relaxed position. So I would say it pulled the bars back a couple inches? It also rose the bars enough to where I can now actually use my stock mirrors and see what's behind me, not just my shoulders lol You will love it!
Old May 2, 2015 | 04:28 PM
  #2657
sincitychoppa
How did it affect the handling, is it harder to dip into a turn now, or was that not affected too badly?
Old May 2, 2015 | 04:39 PM
  #2658
azrchrd's Avatar
azrchrd
Feels like I have more control, was able to get more lean even though my forks are stock and love to dive as soon as I touch the front brakes. Did a few tight U-turns and practiced a few emergency swerves and I have to say it's much better than stock
Old May 2, 2015 | 04:54 PM
  #2659
LA_Dog's Avatar
LA_Dog
Originally Posted by azrchrd
First major mod, 1.5" risers. Will post before and after pics. I'm 6'2", and want to keep the drag bars.
Nice, one thing to consider if I may suggest- Take your stock seat to a reputable upholstery shop and have them shave it down 1.5"-2" by re-sculpting the foam. The stock seat is really flat, thick and sort of pushes you up and forward. For about the same amount of money as risers, you can get the seat modified to suit you and keep the stock riser / sleek setup. I'm 5' 10" and am planning on having a shop scoop the seat out a bit lower in the middle to forward portion so I "sit down more in it". Sometimes when I punch it from a light I'm sliding out of the seat.
Anyway a good seat shop can do this and retain the stock look of the seat by using the exact same cover, just pulling it tighter. An aftermarket seat like Danny Gray will work too, but cost a whole lot more
Old May 2, 2015 | 05:00 PM
  #2660
azrchrd's Avatar
azrchrd
Thanks Dog, I've been looking around for a good seat, cuz like you said I've caught myself sliding out when I goose the fun switch... So until I get a better fit, I have to keep my pillion on. I really want to run solo, love the look when the pillion is off.
