Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old May 6, 2015 | 01:41 PM
  #2721
jgos929's Avatar
jgos929
Originally Posted by LA_Dog
There are four small screws on the back ring of the air filter cover. removing those screws will release the filter cover. the filter itself uses a clamp ring to attach to the intake tube. Loosen the clamp ring holding the entire air filter onto the tube, slide it forward and off the tube. then remove the four small screws on the backside of the air filter. the back ring and forward filter cover will separate in two pieces. i would do all of this on a soft towel. use blue locktight when putting the small screws back in.
I tried all of that long ago. See that black circle in the first pic? That's double sided tape that gets sandwiched between the end of the filter and the inside of the cover when the filter is inserted into the cover. Removing the screws and the ring does nothing because of that double sided tape holding them together. Go ahead and give yours a try when you get a chance and get back to me. That sawzall might be the only way lol!!!
Old May 6, 2015 | 02:14 PM
  #2722
LA_Dog's Avatar
LA_Dog
wow that kinda sucks don't it! I guess the only way to get the cover off the filter is to try and work it loose from the tape. if the tape is not that strong then maybe twisting the air filter back and forth will break it loose. that's not really a good design eh?
Old May 6, 2015 | 02:36 PM
  #2723
jgos929's Avatar
jgos929
The problem is it's really strong. I've tried twisting, pulling etc and the damn thing won't separate. Horrible design if you ask me. The only thing I haven't tried is heat. I wonder if hitting the end with a heat gun might break it loose. I guess it's worth a try
Old May 6, 2015 | 06:17 PM
  #2724
sothai's Avatar
sothai
Originally Posted by Goldsgym
For the both times that I bought them it was on eBay. Around $100 us
Is there a size and type name please?
Searching 'harley badge" brings up thousands of results.
Are they official HD?
Old May 6, 2015 | 09:34 PM
  #2725
Goldsgym's Avatar
Goldsgym
http://www.ebay.com/itm/HARLEY-BAR-A...item25a5cec188
Old May 6, 2015 | 09:43 PM
  #2726
LA_Dog's Avatar
LA_Dog
this one. click link and scroll down. look for a new listing.
http://www.ebay.com/itm/HARLEY-DAVIDSON-Muti-Fit-Fuel-Tank-Emblems-Large-Badges-USA-100-OEM-/181730119296
Old May 6, 2015 | 09:48 PM
  #2727
sothai's Avatar
sothai
Thanks for the links Gents.
$47 shipping?
I'll wait for the next listing from the 2nd link and then see if he will ship here...
Old May 7, 2015 | 06:38 AM
  #2728
Goldsgym's Avatar
Goldsgym
I guess I'll have to have you do my shopping for me and save some coin.
Old May 7, 2015 | 04:10 PM
  #2729
Dalt10's Avatar
Dalt10
Originally Posted by Dalt10
Can someone with a '13 or '14 Breakout put up a picture of where the stock left mirror is mounted? I bought extensions and my left one doesn't fit. Just wanted to see if they changed the '15. I noticed the mirrors are mounted different on each side. Thanks
After looking at different pictures of the Breakout the '15 Clutch lever, Brake lever and housings are different from the '13 and '14. So I guess I bought the extensions for nothing. I'll have to find different mirrors or extensions.
Old May 7, 2015 | 04:16 PM
  #2730
Dalt10's Avatar
Dalt10
Here is a picture of the clutch lever. The housing is bigger is way the extensions don't fit. Right one fits fine.
