Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Aug 1, 2015 | 09:56 PM
  #3551
NSR's Avatar
NSR
I have the Rivera LED headlamp with built in LED signals ... meh ... it's better than the POS light H-D builds the bike with.
It does work perfectly though - no condensation or flickering. It fit the H-D bucket, although I switched to a chrome version from Custom Chrome.
Old Aug 1, 2015 | 11:34 PM
  #3552
harty's Avatar
harty
Default I have been inspired!
I have had my Breakout now for around 18 months and it is time for a change. I have been watching all of you "personalise" your rides and it has inspired me to have a go. Having never worked on a Harley before I was a little nervous, but downloaded a manual and went for it. I have attached a before pic, and a few pics from last night when pulling it apart.
My apologies to all you "chrome boys" out there, but I like the look of the darker bikes these days. New headlight, dash, upper front fork covers and plenty of powder coating should make it look a little different. And hopefully a set of shotguns being shipped to Australia shortly.
I will post a pic when all back together, might be a few weeks.
Cheers for all the good info,
Harty.
Attached Thumbnails The Everything Breakout Thread-20150802_131111.jpg   The Everything Breakout Thread-20150330_130314.jpg   The Everything Breakout Thread-20150801_232106.jpg   The Everything Breakout Thread-20150802_131009.jpg
Old Aug 2, 2015 | 03:46 AM
  #3553
Pigbacon's Avatar
Pigbacon
Harty.
Looking good Sir!
I love the chrome, but the dark Breakout or contrast Breakout both look good.
Old Aug 2, 2015 | 04:37 PM
  #3554
notch.johnson's Avatar
notch.johnson
Default Hydraulic clutch conversion
Originally Posted by notch.johnson
I am in the middle of this conversion using standard FXSB 2014 clutch assy.
I finished the conversion today and I can confirm that the FXSB clutch works with the CVO hydro actuator. No clutch replacement needed.
Old Aug 3, 2015 | 07:11 AM
  #3555
Cumminspwrd's Avatar
Cumminspwrd
Harty.
Where did you buy the upper fork covers, or did you have them made?
Also how do they fit?
Thanks
Old Aug 3, 2015 | 08:39 AM
  #3556
MarkFXSTC's Avatar
MarkFXSTC
Default The Everything Breakout Thread
Any tips for removing rear axle Allen nut without buying massive Allen key. Why not just use a nut HD!!!
Old Aug 3, 2015 | 12:25 PM
  #3557
NSR's Avatar
NSR
Nope ... can't think of anything as big as that, that isn't a Hex key or driver.
Just buy the tool ... you know you want to
Old Aug 3, 2015 | 04:16 PM
  #3558
harty's Avatar
harty
Thanks
I machined them out of aluminium myself. I just got 2 lengths of aluminium tube(OD 60mm, ID 50mm, Length 177.5mm) and machined oring grooves in each end. The oring ID is 49mm(OD forks) and they just sit proud out the ends of the tube so none of the covers touch fork or clamp. They are at the powdercoaters now with everything else turning gloss black.
I did find some that I could buy but I thought they were very expensive for what they are. They were very easy to make if you have access to a lathe.
Here is a link to the set I found :
http://www.dark-parts.com/product/fo...akout/?lang=en
I will post some pics when I get it all back together.
Harty.
Old Aug 3, 2015 | 05:37 PM
  #3559
Da-Rza 21's Avatar
Da-Rza 21
Thanks
you can also just wrap upper fork in 3m vinyl for bout $5
Old Aug 3, 2015 | 06:07 PM
  #3560
burnsy87's Avatar
burnsy87
Putting together a spreadsheet trying to organize before I drop the ~$18k on the bike.. anybody put the Roland Sands Vintage Shortstack bars on? I have mini apes on my Sporty, and as badass as a few of the Breakouts with apes have on 'em on this forum, I'm not sure I want to go that route with the Breakout. I don't like how far the stock bars are forward, and adding a little bit of height would be pretty useful for comfort, I just don't really know what direction to take this as of yet.
