Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jan 8, 2016 | 04:31 AM
  #3931
R1jamn's Avatar
R1jamn
2nd Gear
Hey Goldsgym.
Very nice Breakout. I like what you have done with the blacked out parts.
What method or process did you use to black out the triple tree's?
[/QUOTE]
Old Jan 8, 2016 | 07:15 PM
  #3932
LA_Dog's Avatar
LA_Dog
Originally Posted by JeepXK
Ok i'm still learning this Harley stuff, so don't flame me for this question please....... But is the harley sprockets the same as a sport bike? Going down 1 tooth on a front sprocket is like going up 3 on the rear on a sport bike, Just wondering if it's the same on the breakout?
Welcome to the forum- Yes it is generally the same whether it's a sport bike, Harley or dirt bike. it's not an exact figure but a close approximation.
The most optimal town bike gearing for any new Harley Dyna or Softail is 30 front and 70 rear. Touring guys usually prefer a 30t front / 68t rear. but even with 30/70 there is negligible penalty in 6th as far as economy- it is only a 13% difference vs stock but will make a huge difference off the line and in-gear roll ons, as well as helping to get more out of a performance cam upgrade.
Right now it is 100% verified that you can go 30t front and 68t rear on the Breakout using a front pulley from a tri-glide and a rear pulley from a sportster, with the stock belt- It works fantastic at a roughly 10% improvement in TQ. I am presently working on finding out which 70t pulley from other HD models will fit the Breakout, and the easiest way to do it.
Old Jan 8, 2016 | 08:08 PM
  #3933
LA_Dog's Avatar
LA_Dog
On the above note I have a 70t Arlen Ness rear pulley on the way, for 2004-2006 FLHT. I discovered (via various forums) the 68t sportster pulley that fits the Breakout will also fit those bikes, so I'm anxious to see if it will work out. Given that I have the 30t front pulley installed I have plenty of belt adjustment left to accommodate the 70t.
Anyway, will update with results in a week or two.
Old Jan 8, 2016 | 08:17 PM
  #3934
LA_Dog's Avatar
LA_Dog
Originally Posted by B'stard
Just put some new front fork tubes into my 2013 breakout does anybody know how much oil should these have.Standard forks are 24 3/8" and I put 27 1/2" to corner around tight bends better here in NZ.
Cheers Garry
Not sure on that- but - if you used the longer fork tubes from a Wide Glide, then just use the HD spec for oil fill on that model of bike.
But honestly the #1 thing that will make your BO corner and brake MUCH better is going with single rate springs and better dampers. it's not an expensive or difficult DIY especially given you are already familiar with the process. See my sticky at the top of the softail forum. Trust me, this is a hands down, no question, massive improvement. and it will still work with your longer fork tubes, the only difference will be your oil fill level and longer preload spacers. but you'd buy the exact same springs / dampers parts as for the regular length stock tubes.
[EDIT] - oh wait, ok you have to tell us what fork tubes you used and post some pics- the wide glide fork tubes are only 1.5" longer than stock and you added 3+ inches- I'd love to see that! - Back to the point, you can still use the same upgrade springs / dampers, you'll just cut longer preload spacers and use an appropriate amount of oil. The aftermarket parts vendors I listed in my sticky can help advise you on that, especially Ricor.
Old Jan 9, 2016 | 05:24 PM
  #3935
Dalt10's Avatar
Dalt10
Rode 10 or 15 miles today on the new bike (not really supposed to be riding yet but can't help it, elbow still a little sore). Biggest/only difference I can tell so far is the throttle by wire. Instant throttle response compared to the cable. No lag at all. I like it from what little bit I rode.
Old Jan 10, 2016 | 12:50 AM
  #3936
NSR's Avatar
NSR
"But Doc....the vibrating bike makes my elbow feel better......"
LOL
Old Jan 10, 2016 | 07:58 AM
  #3937
Dalt10's Avatar
Dalt10
Yea, can't understand why my elbow won't heal any faster. Can't help but want to ride it.
Old Jan 11, 2016 | 05:44 AM
  #3938
rodrocket's Avatar
rodrocket
Originally Posted by Rocker B
This site has several available, and there's others..http://www.southern-mc.com/puandsp.html
Thanks for the link, much appreciated
i have already done the tri glide 30T upgrade & still looking for a little more
the 70 tooth idea has me thinking
Old Jan 11, 2016 | 05:57 AM
  #3939
JeepXK's Avatar
JeepXK
Thank you for your response. I'm thinking of just going to a rear sprocket change only. I know on a sport bike it made a significant difference! by just doing that. I look forward to hearing about the 70 tooth rear sprocket change
Old Jan 11, 2016 | 06:38 AM
  #3940
HKMark23's Avatar
HKMark23
I'm 235 lbs, ride solo, and I'm thinking of running my Dunlop E3 250 rear tire at 36 psi cold vs the recommended 42. Anyone else running lower pressures ?
Sorry, I searched the thread and found no prior posts dealing with this.
