Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old May 31, 2016 | 04:12 PM
  #4791
Mencho's Avatar
Mencho
Originally Posted by JimGnitecki
Nope! I looked at that one a long time ago, and it is bigger in some dimensions than it appears to be in a photo!
Here in Texas, you need to get a motorcycle safety inspection annually, and the horn must be there and be in working order.
Jim G
I was also looking at the Stebel Nautilus Compact Twin Air Horn, but also believe is too big.
Old May 31, 2016 | 04:18 PM
  #4792
JimGnitecki's Avatar
JimGnitecki
Originally Posted by Mencho
This looks like a great option, thank you!
I just found and ordered the Arlen Ness 70-204 on Amazon for $169.50 shipped. The photo shows it in black but the description says chrome, so not sure which one I will actually receive. The 70-204 pn no longer seems to appear on the Ness website, nor anywhere else I looked, so no way to check which finish this pn referred to. Either one should look fine on my bike. And I really like (a) the loudness, (b) the true plug and play installation, and (c) the apparent quality.
edit: The Dennis Kirk site has the 70-204 and says it's black . . .
Jim G
Old May 31, 2016 | 04:37 PM
  #4793
Rocker B's Avatar
Rocker B
Originally Posted by LA_Dog
hell if someone does not hear my pipes they sure as hell are not going to hear my weenie little horn.
Ya...that stock horn is a joke... Sounds a lot like this!!...
Old May 31, 2016 | 04:40 PM
  #4794
Mencho's Avatar
Mencho
Jim G
Perfect! Yes looks like the picture is correct but not the description. I will also get one ordered.
Old May 31, 2016 | 04:49 PM
  #4795
Rocker B's Avatar
Rocker B
Jim G
Ya Jim, it's black, that's the one I have...Ebay and Amazon often have the wrong picture and/or discription, good to always go by the part #...
Old May 31, 2016 | 11:28 PM
  #4796
NSR's Avatar
NSR
Has anyone upgraded the horn? Stock horn sounds extremely bad!
Horn? We ain't got no horn ....we don' need no horn ... we don' have to show you any stinking horn!
Old Jun 1, 2016 | 11:13 AM
  #4797
Mencho's Avatar
Mencho
I agree, but unfortunately here in Texas you need a horn for the state inspection.
Old Jun 1, 2016 | 11:23 AM
  #4798
JimGnitecki
In addition, in an accident where someone say cut you off and would otherwise be totally at fault, the other guy's insurance company could use your lack of a horn as a contributory factor to the accident and transfer partial responsibility to you.
Or worse, if a pedestrian walks into your path and you hit him because you had nowhere else to go to avoid the accident and were already inside the required braking distance, but also could not warn him out of the way via a horn, you get an even worse transfer of responsibility because the pedestrian almost always is judged to have the right of way.
A black colored horn is pretty much invisible on our Breakouts, and also does not generally require either maintenance or repair, so why make a big issue of removing it?
Jim G
Old Jun 2, 2016 | 03:45 AM
  #4799
SSTuner's Avatar
SSTuner
Check out this location for the horn.
https://www.hdforums.com/forum/showt...errerid=196562
Old Jun 2, 2016 | 09:43 PM
  #4800
Duke 13's Avatar
Duke 13
Default Mods
Well guys, I've been busy doing several mods but I have no pics yet. Here's what I've done.
National Cycle Flyscreen (Dark Tint)
Relocated plate to vertical axle mount w/Custom Dynamics black frame
Custom Dynamics Black Billet taillight
Custom Dynamics Bullet inserts LED taillight clusters
Custom Dynamics Bullet inserts LED Front Turn Signal clusters
V&H Big Radius 2-1 "Black" from a Fatboy
Changing out the pipes turned out to be the most difficult. I purchased them from a member here and they were priced okay and a little rough. The shields were slightly discolored and had a couple scars on them. UPS beat them up on the end and the heatshield tip was bent in at a 90 degree angle.
I straightened the shield and had them all powder coated black. I know that powder coating isn't as good a ceramic when heat is involved, but it was extremely reasonable so I went with it for the time being.
I also had to purchase 02 sensor adapters (18 mm to 12 mm).
I finished it last night at 11 PM and its been raining all day so I haven't had a chance to fire it up to see how they sound or perform.
Will post pics and results as soon as the weather permits.
