Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old May 8, 2016 | 11:54 AM
  #4691
JimGnitecki's Avatar
JimGnitecki
Originally Posted by HKMark23
I went to Daymakers and LED's for signal lights. These:
http://www.jpcycles.com/product/137-842
work well. You just,,,, put em in.
Yes, that is what I am looking for. I see that they list the breakout as being compatible, but I wonder about that since we have that unique setup where we have running lights, brake lights, and signals all in each side-mounted light housing. But you have actually installed them and they do perform all 3 functions?
EDIT: Oops! I just noticed you are in Canada, where our twin sidelight rera lamps are illegal, so you have a conventional center rear light plus separate signal lamps. This setup would likely NOT work on our U.S. configuration.
Jim G
Old May 8, 2016 | 03:06 PM
  #4692
HKMark23's Avatar
HKMark23
Jim G
I was unaware of that difference sorry.
I do have a conventional bulb in the center brake / tail light unit and I did not need to install any sort of "resistor" you hear about as they are integrated into these LED units. Also, the J&P Cycle website, I'm assuming, wouldn't differentiate between Canadian or US delivered BO's. I don't mean to pitch the things but they were a particularly easy solution for me.
OH !! If you do end up going with these, know that you should be careful to seat the LED disc into the housing, after engaging the bayonet connection, with wires coiled in a way so that the disc is not hung up or cockeyed. It is easy to install these and then reinstall the lens cap without realizing the disc is interfering with one of the integrated lens cap retainers. If you do this, everything will go together well and look OK but you'll loose your lens cap later on when it finally pops out,, somewhere,,, on the highway. This is easy to avoid so long as you know about it.
Old May 8, 2016 | 03:10 PM
  #4693
JimGnitecki
Hey, thanks for trying! The only reason I am aware of the difference between the U.S. and Canadian Breakouts is that my wife and I are planning to import the Breakout into Canada when we move there after she joins me in retirement ("Trophy wife" younger than me, so not yet retired like I am). So, I had to research all the changes required to meet the Canadian safety standards, which differ from the U.S. ones.
Jim G
Old May 8, 2016 | 07:37 PM
  #4694
the_enforcer's Avatar
the_enforcer
Originally Posted by sothai
Quick and dirty fix hopefully:
I rarely ride at night, but did just now and the high beam was so high, it made no difference to what I could see ahead.
What height should it be against a wall 10 feet away please?
Not sure about 10' feet away but the manual shows how to properly adjust headlight at 25' away from a wall on a level surface. I believe the drop calls for 2.1" of center of beam (brightest spot of light) at 25'.
Old May 8, 2016 | 09:34 PM
  #4695
LA_Dog's Avatar
LA_Dog
the "quick and dirty" fix is to loosen the up/down pivot nut so the headlamp housing is snug, won't move on its own at all, but you can still move it with your hand.
then go for a ride at night, preferably a dark flat straight road, turn on high beam and push headlight forward, pull it back until it's right. then after you park tighten the nut and done. BTW I leave mine tight but I can still push it or pull it with a firm hand if needed. I do this on both of my bikes.
Old May 9, 2016 | 05:18 AM
  #4696
sothai's Avatar
sothai
Yes, but at what height?
I'll go with your fix LA Dog. The cops here are clueless anyway, so as long as my field of view is better at high beam, that's all that matters.
Old May 9, 2016 | 06:58 AM
  #4697
JimGnitecki
This approach also enables you to change the setting if you need to carry a passenger at night, as putting a passenger on the seat lowers the rear of the bike enough that if you have truly adjusted the beam for optimal road lighting, it will be too high with the passenger on board.
Back when we rode Nortons, which weighed under 450 lb, and were significantly affected by a passenger's weight, this is what we did.
Jim G
Old May 9, 2016 | 08:08 AM
  #4698
splattttttt's Avatar
splattttttt
Passangers Jim?
What that? LOL
Old May 9, 2016 | 08:16 AM
  #4699
Mencho's Avatar
Mencho
I would love to replace the bulbs on my Breakout, in both the twin rear running/brake/signal lights and the front running/signal lights, with LEDs, but I find the Custom Dynamics website incomprehensible.
Is Custom Dynamics the only source?
What do I order and from where?
I would prefer to avoid cutting or tapping into the stock HD wiring harness. Is there a simple plug and play kit that simply uses the existing bulb sockets?
Jim G
Jim, I used this Custom Dynamics for the rear and they work Great with all three functions, see link below:
Amazon.com: Custom Dynamics GEN-200-R-1157 Red LED 1157 Bulb for Harley-Davidson: Automotive Amazon.com: Custom Dynamics GEN-200-R-1157 Red LED 1157 Bulb for Harley-Davidson: Automotive
Old May 9, 2016 | 08:58 AM
  #4700
mseymour3's Avatar
mseymour3
Jim G
Custom Dynamics look nice but they're expensive. I looked at the Ringz that come in black or chrome and include the lens and all leds but they're around $130 per pair or the inserts are around $90 a pair. I wasn't ready to spend that kind of money so I went to an autoparts store and bought some leds.
Amazon.com: SYLVANIA 1157 Red LED Bulb (Pack of 2): Automotive Amazon.com: SYLVANIA 1157 Red LED Bulb (Pack of 2): Automotive
Amazon.com: SYLVANIA 1157 Amber LED Bulb (Pack of 2): Automotive Amazon.com: SYLVANIA 1157 Amber LED Bulb (Pack of 2): Automotive
Plug right in and work great. They are a tight fit in the reflector housing as you push them in because the plastic above the base is just a bit wider than regular bulbs to start but they do fit. Probably not as bright and pretty as the Ringz but they're much brighter than regular bulbs. And you can switch front and rear for under $50.
Michael
