Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Mar 20, 2016 | 02:32 PM
  #4291
Jimstang's Avatar
Jimstang
Thanks for the great info, Jim.
Another question for anyone who can answer:
I would assume that a bad battery would cause the bike to keep shutting down since the stator is attempting to charge a bad battery and the entire electrical system (fuel pump, lights, ECU, etc) runs off the battery. Am I correct?
Old Mar 20, 2016 | 02:48 PM
  #4292
splattttttt's Avatar
splattttttt
Originally Posted by Jimstang
I suppose it's about time for a new battery. I keep my BO on a tender when it's not being ridden. After a very sluggish start today, it ran but then kept dying as I got about a mile from the house. I ended up limping it home using a lot of throttle to keep it from cutting out on me.
Is anyone running aftermarket batteries? I'm stationed in England and don't want to fork over 165 pounds (about $240) for an HD battery at the dealership.
Any feedback is appreciated. Thanks fellas.
if you're looking for OEM quality, Deaka makes the batteries for the MOCO
Amazon.com: Deka Agm Battery Harley Harley Flht Touring Electra Street Glide Ultra Flhtcu: Automotive Amazon.com: Deka Agm Battery Harley Harley Flht Touring Electra Street Glide Ultra Flhtcu: Automotive
Old Mar 20, 2016 | 03:33 PM
  #4293
snappyfish's Avatar
snappyfish
Completely different bike but I had a Gixxer 600 was left for a while over winter took it out for a spin and died while giving it some throttle on a dual carriage way on a bend in the middle of fields.
Called the AA got me started and I limped home with them following, changed the battery and was all good
P.S Currently looking for a breakout
Old Mar 20, 2016 | 07:50 PM
  #4294
rodrocket's Avatar
rodrocket
Has anyone here fitted a set of the D&D lowcat pipes to there Breakout
I am interested in hearing there thoughts on them & also if someone can confirm a part number for me
The only part number for the Breakout in Chrome that I can find is 610-32 or is there different numbers for different baffle arrangements.....
regards
Rod
Old Mar 20, 2016 | 08:22 PM
  #4295
cdonis's Avatar
cdonis
D and D is awesome. I believe there is only one baffle like my bobcat. Call them and talk to Leonard. The chrome is the 610-32
Old Mar 20, 2016 | 09:56 PM
  #4296
LA_Dog's Avatar
LA_Dog
you have a computer controlled bike- put in a new good battery and don't ride it around with a bad or weak battery.
as far as battery tenders they only work for so long then the battery needs to be desulphated. if you buy a battery "maintainer" that will provide desulphating pulses and has specific modes to prevent that type of problem it will keep your battery lasting longer. and I would not buy an OE battery I'd get something better in quality and cranking amps. always get the largest cranking amp battery you can for the $.
Old Mar 21, 2016 | 02:15 AM
  #4297
SSTuner's Avatar
SSTuner
As far as battery tenders they only work for so long then the battery needs to be desulphated. if you buy a battery "maintainer" that will provide desulphating pulses and has specific modes to prevent that type of problem it will keep your battery lasting longer. and I would not buy an OE battery I'd get something better in quality and cranking amps. always get the largest cranking amp battery you can for the $.
Todays battery chargers are much better than yesteryear. I use a NOCO Genius G3500 Smart Battery Charger. Research AGM and do a compare to the old style batteries and you will see why it is important to use a newer style charger vs just a trickle unit.
Old Mar 21, 2016 | 05:58 AM
  #4298
JimGnitecki's Avatar
JimGnitecki
I erroneously referred to my battery charger as a "Battery Tender", but it is actually a "smart" charger sold by Harley. A nice feature of the model I bought is that it is advertised as "water resistant", so if you store your bike outdoors under a storage cover, this battery charger can tolerate rain conditions as long as you aren't stupid: place it UNDER the crankcase to keep it out of direct rain, and place it on a board or something else to elevate it above ground level.
The HD model also comes in 2 different amp ratings, and has 2 lights that communicate proper connections and charging status.
The convenient way to use one is to have a harness permanently mounted on the bike that you simply plug the charger into as needed.
Jim G
Jim G
Old Mar 21, 2016 | 05:51 PM
  #4299
weezl's Avatar
weezl
Hello everyone!
first post on this forum, I picked up a 2015 breakout in radioactive green, last wednesday, so i'm coming up to 2 weeks on it, and so far, i'm loving the bike! I will admit, it is my first harley, so I am definitely not all knowing in the harley specific end of things, but it is not my first bike.
I've got lots of questions i'll be asking over the next while, and a bunch of places i need to put money that I don't have. The first question, which I can't seem to find much of an answer for is what all is needed to change the bars on the breakout. I love the look of the breakout, i love the feel, but as a tall guy (6'2") I find that the low drag bars have me reaching for them and my arms get strained, and my back gets sore riding for more than about 20 minutes. I am a part of my local chapter of Bikers Against Child Abuse, so I ride year round, and with the way we work, i'm often on rides to do our work, that is several hours long, as such, both fashion and function are incredibly important to me.
I'm looking at ape hangers of some sort, probably something between a 10 and 16" I'm not wanting to dry my armpit hair all day long, but something just lower than my shoulders would be a GREAT help on comfortability. I tried searching around on the forum and this thread, but with 300 or so pages, it's hard to read every post. I'm looking for something similar to the yaffe bars, or chizzled bars. The thing I can't find is what length of wiring and cables I need. I spoke with my local dealer and they gave me a stupid answer, I was told to put the bars on, get everything assembled then trace out the path of where I want everything to run with string, then take that measurement, add a few more inches, and bring it to them to order. Yeah, that would work, but I don't want my bike to be down for a week or two for parts to be ordered in... I read the CVO/Blackline (Blackout/Breakline) thread, and with some of you guys waiting 2 months for your dashes to come in, that's just not acceptable for me, in the middle of making this switch, only to find I might have measured wrong.
I would like to be able to have a pile of boxes, and put everything on in one day, and be done with it. I'm sure there's enough people on here who have either figured it out some mathematical way, or measured with string, or done the trial and error method to find what works and what doesn't.
and a better question would be, would it be best for me to start a new thread on bars for the Breakout, so the answers are not lost in the middle of this 100000 post thread?
Old Mar 21, 2016 | 06:47 PM
  #4300
HKMark23's Avatar
HKMark23
Originally Posted by weezl
Hello everyone!
Welcome bro. I think you'll get your answers within the next half dozen posts or so.
With OEM bars being ground zero, so to speak, if you plan on going to say, 16" bars why not measure your existing cables and then add 16" plus (minus) any adjustment in slack you deem desirable based on existing cable routing ?
Or, you could just go here:
https://www.denniskirk.com/search/20...ring+harness.q
As you're a fellow Canukistani, here's a Canadian vendor:
https://www.canadasmotorcycle.ca/cat...and+cable+kits
