Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jan 11, 2017 | 01:17 AM
  #5321
Nostradamus74's Avatar
Nostradamus74
Longer fork tubes for sure, maybe dyna wide glide or similar. If you observe the lower part of the frame you'll notice the front part is higher than the rear. The chopper attitude of the BO has been generally enhanced also by adding a tall sissy bar.
Old Jan 11, 2017 | 04:08 AM
  #5322
EagleRay's Avatar
EagleRay
Originally Posted by Dalt10
Not sure but looks like they just have longer fork tubes.
+1....longer tubes
Old Jan 11, 2017 | 08:11 AM
  #5323
EricRay's Avatar
EricRay
Wanted a windscreen a little bigger than the Fly Screen, but not many options for the Breakout. So I had Gustafsson Plastics, Inc make me a custom. Using same mounting hardware as the Fly Screen. I like it. Haven't put it on yet, at work, just drilled the mounting holes.
Old Jan 11, 2017 | 01:02 PM
  #5324
EagleRay's Avatar
EagleRay
Originally Posted by EricRay
...but not many options for the Breakout....
Yeah, the Breakout is not a windshield bike...
Old Jan 11, 2017 | 04:51 PM
  #5325
tphykitt's Avatar
tphykitt
I have the tall sissy bar.. was wondering if this had any negative effects? Longer fork tubes that is..
Old Jan 11, 2017 | 08:14 PM
  #5326
02603SEC's Avatar
02603SEC
I don't think the touched the frame, but the front forks look to be possibly 4" over stock. Looks badass, but it will change rake and trail changing the handling characteristics of the bike.
Old Jan 11, 2017 | 08:43 PM
  #5327
JimGnitecki's Avatar
JimGnitecki
You bet longer forks will have a negative effect. They will make the bike turn even more reluctantly than it already does with the stock Dunlop rear tire. If you are going to lengthen the forks, I strongly suggest you first change to a tire with a better profile for tight turning - like the Pirelli Diablo 240 I am running. There are probably other good tires out there too, but don't keep that cement-overshoes Dunlop.
On the plus side, the longer forks will improve the ground clearace during cornering, so your footpegs won't drag quite as soon.
Jim G
Old Jan 11, 2017 | 09:26 PM
  #5328
tphykitt's Avatar
tphykitt
I never understood what the 'trail' is. It looks badass, I think I want to do it but I don't want to regret it.
I already ripped the pegs off both sides from cornering lol I would def like more lean. The dunlops are awful. I run through tires like CRAZY. Someone recommended the michelin power commander 2. Hadn't heard of the pirellis until now.
Jim G
Old Jan 11, 2017 | 09:47 PM
  #5329
JimGnitecki
When I put on the Pirelli, it was like the bike lost a set of concrete overshoes. The difference was THAT dramatic. Not only ois the profile better on the Pirelli Diablo, but it also weighs approximately 5 to 6 lb less than the Dunlop. That is no exaggeration - I compared the weights before I bought the Pirelli.
Jim G
Old Jan 11, 2017 | 09:54 PM
  #5330
02603SEC's Avatar
02603SEC
Check this out
http://www.motorcycle-superstore.com...explained.aspx
