Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Dec 18, 2016 | 07:48 AM
  #5301
JimGnitecki's Avatar
JimGnitecki
Originally Posted by rodrocket
Thanks for the tip on machining the pulley down Bodgie
Just wish I could find a 70 tooth rear in the same style as what's on my 2014 CVO Breakout
I have had the 30 tooth on the front for over 18 months & love it
If you have the 2014 CVO, then you have the HD Turbine wheels, right? Those are the wheels that my dealer added to my 2014 non-CVO Breakout. I then did the 30T / 70T conversion. I was able to buy a Performance Machine pulley on eBay that worked perfectly with the Turbine wheels:
The hub spacer had to be machined to the correct size for the HD axle. If you check out LA_Dog's gearing change thread which is a "sticky" on this Softail forum, and look at my series of postings on my mod, you will know edxactly what to do.
My specific mod took a long time simply because I wanted someone experienced in this kind of hub mod to do the spacer, and that shop had a long work queue at the time.
I'm sorry I do not know the Performance Wheel part number, but it exists.
Check out my postings on LA_Dog's gearing thread.
Jim G
Old Dec 18, 2016 | 10:02 PM
  #5302
rodrocket's Avatar
rodrocket
Thanks Jim, much appreciated
heading over there now
Old Dec 18, 2016 | 10:34 PM
  #5303
rquest's Avatar
rquest
Originally Posted by UHDhog
UHDhog,
You know how you always kinda have a favorite bike. For the longest time I thought mine was the Black BO with your wheels but I think it's been replace by the white one. What a beautiful bike you have my friend!
Old Dec 19, 2016 | 03:34 AM
  #5304
bodgie1307's Avatar
bodgie1307
closest I found was the HD 6 slot at least with HD pulley no spacer is required..
Those that are doing the pulley swap the lower guard pn 60316-0A is a 70T from 00-06 softail and my local dealer confirms bolt pattern matches that of the breakout..however we won't know if it will allow for the 9mm shift in wheel location on the 30/70 swap..min gets done the week January 9th so will give the guard a go and report back..amazingly they have one in Stock at local dealer.
Old Dec 19, 2016 | 07:30 PM
  #5305
rodrocket's Avatar
rodrocket
Thanks Bodgie
Do you know the part number on the pulley & is it Chrome
I read the other thread about where Jim changed his pulley & it seems like he went through a lot of trouble
Old Dec 19, 2016 | 08:06 PM
  #5306
bodgie1307's Avatar
bodgie1307
Thanks Bodgie
HD40447-01 Chrome it was readily available,doesn't need spacing and about same cost as aftermarket
Old Dec 26, 2016 | 02:24 AM
  #5307
rodrocket's Avatar
rodrocket
Thanks Bodgie
much appreciated
regards
rod
Old Dec 27, 2016 | 02:15 PM
  #5308
rquest's Avatar
rquest
Originally Posted by SSTuner
Swapping out the front forks would be cost prohibitive at this time unless you can get it all from a CVO Pro Street that has been "salvaged".
I wonder if anyone's ever tried to put one of these on their HD? The R1 is an incredible ft end and you could also utilize dual ft brakes!
Old Dec 27, 2016 | 04:21 PM
  #5309
NSR's Avatar
NSR
Just get the R1 and ride it...or do the front suspension upgrade that is stickied at the top of this Softail forum.
Old Dec 27, 2016 | 04:49 PM
  #5310
rquest's Avatar
rquest
A lot of people like the look of the inverted ft end + the dual brake set-up. $450 ain't a bad price for all of that
