Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Aug 5, 2018 | 02:07 PM
  #6421
cdonis's Avatar
cdonis
New ultracool 2.0 oil cooler. Fans turn on at 210 degree oil temp.
New flo motorsports mini boards and pegs.
Old Aug 5, 2018 | 07:01 PM
  #6422
NSR's Avatar
NSR
Got a pic from further back? I'm curious about how the bike looks with a cooler mounted on it.
Old Aug 5, 2018 | 09:38 PM
  #6423
donk_316's Avatar
donk_316
Here's mine
-SE 117" engine upgrade
-SE 259E cams
-SE Left side Timken bearing upgrade
- 3" Rinehart slip on black mufflers
- SE Street Performer Tuner
-Fred Kodlin signature Mustang solo and matching pillion, customized
-HD oil pressure gauge, customized
-3" forward control relocation, customized
-LED rear brake / running light
-Kijima plate relocation bracket
-Leatherworks custom solo bag
Attached Thumbnails The Everything Breakout Thread-photo569.jpg   The Everything Breakout Thread-photo981.jpg   The Everything Breakout Thread-photo245.jpg
Old Aug 6, 2018 | 03:14 PM
  #6424
Vinman411's Avatar
Vinman411
Anyone know a better rear seat that fits the stock mounting hardware?
Old Aug 6, 2018 | 07:45 PM
  #6425
cdonis's Avatar
cdonis
Here you go NSR
Old Aug 7, 2018 | 03:32 PM
  #6426
weezl's Avatar
weezl
jeeze that ultracool cooler looks really good! actually looks like it's supposed to be there!
been toying with getting a cooler for a bit now, my bike runs SO hot!
edit: it says it doesn't fit bikes with ABS... did not all breakouts come with ABS??
Old Aug 7, 2018 | 04:07 PM
  #6427
Rocker B's Avatar
Rocker B
Originally Posted by Rocker B
I went ahead and ordered a set of black pivot bolt covers (HD part #47649-09). https://www.harley-davidson.com/store/NaturalSearchDisplay?searchTerm=47649-09&userSearchTerm=47649-09&storeId=10152&catalogId=10051&langId=-1&pageSize=45&beginIndex=0&searchSource=Q&sType=Si mpleSearch&showResultsPage=true&pageView=image&res ultCatEntryType=2
It says they wont fit the BO, but I'll find out, and confirm the part number, and fit (with the V&H Big Radius pipes), when they arrive.
Just confirming that these HD swingarm pivot bolt covers DO fit the pre '18 Breakout!!
With the V&H 2 into 2 exhaust, I removed the (2) bolts at the mount and was able move the upper pipe out enough to slip the right side cover on.
Old Aug 7, 2018 | 04:46 PM
  #6428
cdonis's Avatar
cdonis
not all had abs. May want to check jagg. The may make a side mount.
Old Aug 8, 2018 | 12:05 AM
  #6429
weezl's Avatar
weezl
oh crazy! ok i'll look at jagg, or see what other options there are.
that'll be on of my next projects for the bike, right now i'm working on the 30/70 swap. i've paid for most of the parts (maybe all?) just waiting for them to show up!
need to find someone who can confirm if the spacer that's stuck in my new pulley is the right one, or if it's some random one that got stuck in there for some reason...
Old Aug 17, 2018 | 05:25 PM
  #6430
K9F's Avatar
K9F
Returned from holiday yesterday and on final push to get this completed now before the fine weather season ends. Having been 'two-pack' filled,' painted and then hydrographically dipped with 3D carbon transfer and a further three coats of lacquer I finally collected fender from paint today.
Another couple of hours fitting it.
And a further couple hooking it all up and tidying up the wiring.
