Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Mar 21, 2019 | 07:24 PM
  #6741
Khloesdad's Avatar
Khloesdad
Oh yeah. Low Range. Sure I've seen that before. {Many times}. Sorry for my ignorance.
Old Mar 21, 2019 | 09:27 PM
  #6742
vivid black's Avatar
vivid black
Originally Posted by vtchopperdude
Ok fellas, I'm having my first "issue" with my Breakout. I've noticed several times that when I start the bike, the LO RNG will be on the display. It seems to correct itself after riding, but why is it doing that on startup? For example, I filled my tank up, rode home, and then when I started it today, the display automatically defaulted to the odometer, and when I cycled through the display, it read LO RNG. I normally leave it on the Gear/RPM display, and I've noticed that occasionally when I start the bike, it will default to the odometer. Why is it doing this?
You put new dash on bike maybe wire pinched or not secure on fuel switch? But it runs so that should be ok?
Old Mar 21, 2019 | 11:09 PM
  #6743
Superdog3:16's Avatar
Superdog3:16
Has anyone found, or figured out, any tank trim, or flush mount cap, or anything at all for the new ones? Fxbr/s?
Dayum.......
Old Mar 21, 2019 | 11:16 PM
  #6744
Hdbkstl's Avatar
Hdbkstl
Got my pm intake on and power vision. In all honesty, feels about the same, but looks a lot cleaner. Jmo
Old Mar 22, 2019 | 08:10 AM
  #6745
Teddy Vedder's Avatar
Teddy Vedder
I have the same issue, been happening for the past year, I’ve never messed with trim. It’s a known issue in the forums with several HDs but for some reason nobody ever seems to come up with a solution. Several people have detailed their visits to the stealership service dept, their solution is always “replace the speedo”, but people still have the issue afterwards. I guess they decide to live with it like I have. I just reset my trip Odometer every time I fill up, and make it back to the gas station before I hit 130 miles.
I’m still hoping someone figures it out.
Old Mar 22, 2019 | 08:56 AM
  #6746
Breakout73's Avatar
Breakout73
If you want to experiment with a speedometer, 2 weeks ago I swapped out my stock speedo (3800 miles) for the HD tach/speedo. It's mint.
It's in a box in my basement.
I'll ship it. Make me an offer!
Old Mar 26, 2019 | 07:52 PM
  #6747
Saloondawg's Avatar
Saloondawg
4th Gear
Default Lo rng
I had the exact same issue with my 2016 Breakout. Took it to the dealer where I bought it and had the service department check it out. They tried several things to fix it like replacing the fuel sensor in the tank, replacing hand controls. Nothing worked. Since it was under warranty, I just kept going back. Got to be a weekly thing. After about the 4th or 5th trip, they put a "Master Tech" on it. He said he traced it back to a faulty BCM. They replaced it and it's been trouble free since. Hope this helps.
Old Mar 26, 2019 | 09:13 PM
  #6748
vtchopperdude's Avatar
vtchopperdude
Originally Posted by Dalt10
Mine does the same exact thing.
I have the same issue, been happening for the past year.
So it's a common problem. My bike only has 1100 miles on it too.....
That's good that a new BCM fixed the problem, but that's some shitty engineering if lots of people are having problems. My FP3 doesn't throw any codes for a faulty BCM, but who knows?!?!?! I guess I'll just live with it. I don't think a BCM would be cheap...
Old Mar 26, 2019 | 10:43 PM
  #6749
Rocker B's Avatar
Rocker B
Yes, I think it would be costly...I believe a new BCM also requires a Digital Tech. to pair it with the ECM, so the dealer would need to install it, or you'd need to haul your bike to them after you install it, for it to work!!
Old Mar 27, 2019 | 07:52 AM
  #6750
vtchopperdude
Guess I'll just live with it. Like I said, my FP3 doesn't throw any codes for it, and the bike runs great. I don't think I'll mess with it. But still, that's some bs for a almost brand new bike IMHO...
