Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Mar 27, 2019 | 08:33 AM
  #6751
Vinman411's Avatar
Vinman411
Anyone replace the factory kickstand on your breakout? is there a difference between regular and cvo? I wouldn’t think there would be but ya never know.
Old Mar 27, 2019 | 08:40 AM
  #6752
HKMark23's Avatar
HKMark23
I had to put a shoe on my stand after extending the forks by 2". Drilling these puppies is hard work, (without a press). The J-stands are made of very hard steel. They are also held in place via a pretzel clip, not a nut, which is nice to know if you ever want to remove one.
Old Mar 27, 2019 | 09:26 AM
  #6753
Teddy Vedder's Avatar
Teddy Vedder
Originally Posted by vtchopperdude
Guess I'll just live with it. Like I said, my FP3 doesn't throw any codes for it, and the bike runs great. I don't think I'll mess with it. But still, that's some bs for a almost brand new bike IMHO...
just spoke to my dealer and he told me there was a recall for this, but that my bike had the repair (reprogram BCM) done a month before I bought it in 2014. He wants to take a look at it and see if it’s something they can claim under the recall.
Here is is what I found on the BCM recall.
https://www.bizjournals.com/milwauke...s-several.html
Probably won’t take it in until I leave town next week since it’s my DD. I will let you all know what I find out.
Old Mar 27, 2019 | 09:38 AM
  #6754
Khloesdad's Avatar
Khloesdad
Does anyone know if the new style {small} speedo assm from the 18+ BO will work on a 15? Is it plug and play? Thanks.
Old Mar 27, 2019 | 09:40 AM
  #6755
vtchopperdude's Avatar
vtchopperdude
From the article...
"The scope of the recall affects some model year 2013-2014 FXSBE and 2014 FXSB model Softail Breakout motorcycles. The problem is the motorcycle may run out of fuel while the indicator shows that the motorcycle still has gas, even before the low fuel warning lamp illuminates."
My problem is slightly different, and I have a 2016. I get the LO RNG and the fuel light at appropriate times. My issue is that the LO RNG is on when the bike is started and idling. Once I start moving, the LO RNG goes away and the correct miles until empty is displayed. It's not a huge deal, but still, it shouldn't do that...right?
Either way I guess it wouldn't hurt to call the dealer and see if that recall extends past the '14 model year.
Old Mar 27, 2019 | 11:30 AM
  #6756
Teddy Vedder
From the article...
Yes, my problem is the same as yours and not exactly what they described in the recall. However, I’m going with faulty fuel indication is faulty fuel indication. I’ve never had it read full and be empty, rather it’s been the opposite.
Nevertheless, I think it’s all pointing the the BCM which is $249 from the dealer for the part if they have to replace it. Haven’t figured out what the labor is yet. I’ll let you guys know as soon as I get more info.
If it ends up being a $500 repair, I’m just going to run it the way I have for the past three years by resetting my trip mileage at every fill up.
Old Mar 27, 2019 | 12:24 PM
  #6757
vtchopperdude
Same. Unless my bike starts running badly or I get constant erroneous fuel display indications, then I'll probably just leave it alone. I can spend that $500 on other cool **** for the bike
Old Mar 27, 2019 | 02:22 PM
  #6758
Superdog3:16's Avatar
Superdog3:16
Warmed up a bit in Ohio. Got a whole 270 on the clock, 30 or so today. Liking it so far!
Old Mar 27, 2019 | 08:30 PM
  #6759
vtchopperdude
Alright fellas, interesting twist to the story of the LO RNG. I had my bike on the battery tender last night. I started it up today, and no LO RNG. I moved it around to get to some stuff in the garage. It sat for a few minutes, then I started it back up, and no LO RNG. Then it sat for a another few minutes. I started it up for a third time, and it went to the Odometer display, then flashed LO RNG and the low fuel light came on. I rode it around the block, and no change. So, I went up to the gas station, and put 3.2 gallons in it. The trip meter said 101 miles. Low fuel light should come on at 1 gallon right? And only 101 miles on the tank...shouldn't I be getting like close to 200?? Electrical gremlins...? I read on another thread about someone having a dirty negative battery connection, and once they cleaned it, the LO RNG issue went away. Well, this bike is pristine!!! I mean not a spec of dust on it, and only 1100 miles. I don't think dirty connections are my issue. Everything else works properly. I do get 2 codes on my FP3. They are for the front turn signals because I didn't wire in the running light function when putting the slimline LEDs on. But, I wouldn't think that would cause a LO RNG indication...would it?
Old Mar 27, 2019 | 08:46 PM
  #6760
Breakout73's Avatar
Breakout73
Question: how old is the battery? I know it's on a tender but if it doesn't hold a charge the electric gremlins started there for me. Just throwing it out there again. I'm sure you've thought of that though.
