Now your cooking. I'd do a 98" kit. I used GMR.
Have big boyz smooth out your heads, se cam plate with Andrews 37 cams. Adj. push rods. You'll spank those 103's all day long.
I decided to go with HQ for the tc 120 kit. I ordered the s.e. pro crankcase set #24400033. I also received order for s.e. pro bigger bore cylinder kit 4.060 bore.I have been busy but I will be sending out heads and cylinders to HQ for tc 120 kit work.Im not sure what cams I can order for this kit with new cases and s.e. hydraulic cam chain tensioner kit . here are the parts I have so far.
cam service gasket kit
cam spacer kit
cam drive gear retention kit
cam bearing assembly
s.e. hydraulic cam chain tensioner and high flow oil pump upgrade kit
s.e. roller rockers
s.e. tappet kit
s.e. adjustable pushrods and black covers
s.e. pro 4.060" bigger bore cylinder kit black highlighted
