Blue pipes
Old Jun 3, 2015 | 03:41 PM
3bc's Avatar
3bc
Default Blue pipes
My powder black slip ons (bassani) are starting to turn blue where they connect at the headers. A couple quick Q's:
1. This means I'm running too lean, right? Scary as my mileage is already awful!
2. Is there anyway to clean this off? In my case it almost seems to be sitting "on top" of the pipes if you will, rather than "in" the finish, but I'm afraid to scrub too hard.
Thx!
Old Jun 3, 2015 | 03:49 PM
jamzcl's Avatar
jamzcl
Running lean shouldn't have anything to do with your pipes bluing.
Old Jun 3, 2015 | 04:33 PM
SLV's Avatar
SLV
The blue you describe is different than traditional "blueing" of stainless steel exhaust pipes. You are simply experiencing discoloration of the coating due to its inability to handle heat. My black V&H Pro Pipe on my Dyna started turning a wierd gray/purple after about 12k miles.
If they are relatively new, I'd ask for a warranty from Bassani. If not, you have a few options:
  1. Have them powder coated with high temp powder.
  2. Have them ceramic coated by Jet Kote or one of the other hot rod houses.
  3. Sand them down and paint them with high temp ceramic paint from a rattle can (available at your friendly Lowes, Home Depot, etc.)
Being that they are slip-ons and easy to remove/re-install, I'd go with option three. It holds up well and can be re-painted as often as you like for very little cash.
Jet Kote is really good stuff, but costs quite a bit.
Old Jun 3, 2015 | 04:36 PM
SLV's Avatar
SLV
I just saw that you are in Chicago. Look up The Powder pro and ask for Joe. He's a forum member (Dyna section mostly) and will treat you right as a forum member. They do excellent work and are in the Chicago area.
Old Jun 3, 2015 | 08:28 PM
PaPaBlista's Avatar
PaPaBlista
I sprayed mine with normal ole 1500 degree high heat flat black 5.99 a can at any parts store 4000 miles no problems, scratches are easy to touch up too...
I've decided to go the same way with my new Sporty project also.. I like the pipes they just look rough I sand them with some 180 grit paper before spraying..
6165hd
May 12, 2018 03:37 PM
escalade6103
Jul 28, 2015 11:01 PM
Warrior Redleg
Mar 4, 2011 10:43 AM
dawg
Feb 17, 2010 05:52 PM
hogsolo
Nov 17, 2008 04:35 PM
