XLCH to XLH battery question
Old Jan 12, 2016 | 12:51 PM
justme49002's Avatar
justme49002
5th Gear
Default XLCH to XLH battery question
I own a 1971 XLCH. I am converting to electric start. My question about the battery. Do I have to get the original battery for an XLH, or can I get any battery with enough cold cranking amps? There are several batteries that are 6 7/8 by 4 inches with 310 CCA.
Old Jan 12, 2016 | 01:40 PM
Scuba10jdl's Avatar
Scuba10jdl
Just needs to fit, doesn't have to be original. If you're still using the lunchbox oil tank then battery sizing will be tough. Much easier to use the XLH tank and fit a big battery.
Old Jan 12, 2016 | 01:57 PM
grbrown's Avatar
grbrown
Wink
That 310 CCA battery is more powerful than the original battery on my Evo Glide! Should be enough for your XLCH IMHO. Modern AGM batteries have significantly greater performance than batteries of even a decade ago, which I suspect that one is.
Old Jan 17, 2016 | 10:06 AM
justme49002
5th Gear
Thank you for the info. Found a Harley dealer that many say has a Sporty guru working there. Went and talked to him. He told me the same as you that the smaller battery with 310 CCA would probably start my bike. But the smaller batteries only have about 17 amp hours and would not be good if making several stops around town. Recommended sticking with the larger original battery because it has 28 amp hours.
Old Jan 17, 2016 | 07:52 PM
hscic's Avatar
hscic
I am using an AG Lithium 16 cell battery with 480CCA capable for everyday use on street bikes up to 96ci, but you are right...it only has 15 amp hours. The 600 CCA for up to 140ci has 18 amp hours. It is small...L4.25"XW3.25"XH5.25"
Old Jan 18, 2016 | 07:08 AM
Carter Stindberg's Avatar
Carter Stindberg
Just to add my own relevant post here...
The pic is of the 1970 Sportster XLCH I bought brand new when I was a kid.
I only rode it for maybe 3 years or so before life happened and it just sat for quite a few years.
Then around 1982 give or take, it turned out that one of my customers owned a motorcycle salvage yard, so he rummaged through his kingly stash of parts and put together for me a complete conversion for electric start.
I can't speak about availability of parts today, but you'll note that I retained kick start capability along with the addition of electric start.
Also note the model H oil tank, and of course, I used the H battery tray and correct size battery as well. I was very happy to make it a true H bike but still keep the CH look overall.
I have kept ALL of the original parts that I had changed out over the years (except the cigar exhaust pipes... they're long gone), but I have still not come to any conclusion that I should put it back stock. I like it too much the way it is. I'll let the second owner who gets it after I'm dead do what he wants with it.
I just bought a 2007 FLHP Road King that my old butt will probably ride a lot more these days, so the Sportster is what it is and will likely stay that way.
Old Jan 18, 2016 | 12:11 PM
hscic's Avatar
hscic
I also carry an AG micro jump starter/charger in my saddlebag which can jump trucks, cars, and motorcycles many times over for piece of mind and to help others if needed. Check out DK Customs.
Old Jan 18, 2016 | 08:24 PM
BigTwins's Avatar
BigTwins
I always replace my Street Glide battery Every 2 years and put the old battery in my 77 Sporty. Works out great.
illraptorskiUSMC
Electrical/Lighting/Alarm
Feb 13, 2015 07:05 AM
xltjim
Ironhead
Apr 13, 2012 08:49 PM
scooby doo
Apr 6, 2008 02:35 PM
rgm
Apr 4, 2008 01:57 PM
aeto72
Ironhead
Jun 15, 2007 06:18 PM
