Ballpark labor/parts examples for Rubbermount Transmission repairs?
Old Mar 27, 2016 | 03:02 PM
monckywrench's Avatar
monckywrench
Default Ballpark labor/parts examples for Rubbermount Transmission repairs?
I'm an experienced mechanic but have never done a transmission R&I on a late Sporty and wondered what dealers and indys get for the job and how many flat rate hours it takes.
I'll do my own work but want bargaining information since I see late Sportsters turn up for sale after obvious owner shock at repair costs. Might be a fun way for me to add one to the fleet.
Thanks in advance!
Old Mar 28, 2016 | 12:44 PM
John Harper's Avatar
John Harper
If it's a 2004 and later, removing transmission requires complete disassembly of the case halves. Pull the heads, jugs, etc. The whole enchilada.
2003 and earlier, you can simply remove the transmission from the engine without much effort.
John
Old Mar 30, 2016 | 01:21 PM
monckywrench
I'm aware of the mechanical differences. I'm looking for ballpark time and dollar figures for private party purchase negotiating leverage.
Minimum parts would be a complete engine gasket and seal set and piston rings plus whatever died in the transmission, and since any mistake between the cases is another engine teardown the entire transmission should be considered trashed if any of it fails.
If I can prove by irrefutable numbers malfunctioning gearbox repair is more expensive than a replacement used engine that is obviously useful when buying a broken Sporty. My labor won't cost me anything but time and I enjoy the work.
Amusingly, my mechanic bro who grew up wrenching in the 1950s said many early K-models ended up junked because they had no trap door and labor wasn't free then, either. I'd love to have some of those "junkers" today.
Old Mar 30, 2016 | 04:25 PM
HarleyScuba's Avatar
HarleyScuba
Figure on, at least, 16 hours labor, at shop rate.
16 x $120 = about 2 grand.
Years ago, I was a passive witness of the procedure on a 2006 XL1200 Roadster by a Certified, Harley Factory trained tech, in a dealership, with all the factory tools available, on a lift. It just takes a lot of time to tear all that apart and re-assemble. The Tech had plenty of experience, and the bike was on his lift for 3 days (I'm sure he had other crap going on, too, so I figure at least 2 days). I'd think a toasted tranny would be worth around $2,500 of bargaining.
Old Apr 1, 2016 | 02:34 PM
monckywrench
Thank you very much!
That will aid me in the hunt.
Old Apr 1, 2016 | 07:21 PM
SWMB's Avatar
SWMB
Excuse me for hijacking your thread but I've a dumb question. Do the big twins have the same deal where you hafta tear the engine down to get at the tranny.
Old Apr 1, 2016 | 08:40 PM
ev0lution7's Avatar
ev0lution7
No the tranny is separate.
And it's cheaper to buy a low mileage 06+ 1200 on eBay than it is o fix the tranny.
I replaced my blow up 04 motor that broke and seized the oil pump and ruined the cases. For $1600 free shipping 1200c motor. 9k miles from a salvage bike (08)
Old Apr 2, 2016 | 05:59 AM
grbrown's Avatar
grbrown
Wink
The primary has to be dismantled, then the right side of the trans casing removed, to get the gears out.
Old Apr 2, 2016 | 07:08 PM
Scuba10jdl's Avatar
Scuba10jdl
I'd call splitting the cases and back a 20 hour job depending on the condition of your nuts and bolts. That and whatever other work you want done while its apart.
jrockstar
Shovelhead
Nov 7, 2017 09:48 PM
dzuniga770
Shovelhead
19
Aug 21, 2016 01:23 PM
NavyCharles24
Aug 18, 2013 04:22 PM
jackinthebox
Dec 31, 2008 10:09 PM
mattsvtcobra
Ironhead
Aug 24, 2008 02:15 PM
