Help with p0122 code throttle position sensor
Old Jan 9, 2017 | 07:39 PM
cvaria's Avatar
cvaria
Originally Posted by Matthew Valinsky
Also my throttle gets stuck at times could that have anything to do with it
possibly. i can't say. that a safety thing you probably want to look into. take it one step at a time.
i had something similar happen recently. turn out to be cables. but... i can't say that's what is going on here.
A. https://www.hdforums.com/forum/sport...l#post15777312
B. https://www.hdforums.com/forum/sport...l#post15802978
Old Jan 9, 2017 | 07:54 PM
Matthew Valinsky's Avatar
Matthew Valinsky
Well I'll start by cleaning the throttle body. Don't think it's the cables because they seem good to me. If that doesn't work I'll start with the multimeter. Where would I connect the multimeter at?
Old Jul 8, 2024 | 08:41 AM
TimHixson's Avatar
TimHixson
2009 sportster 883 iron Code P0122 like above.
I believe I might have the wrong tps sensor on it. At the TPS location the shaft sticking out spins clockwise when opening the throttle. When I test my TPS it is under tension to go counter clockwise. When I test the TPS sensor it has .51v at its home position and turning it counter clockwise it goes up to 4.8ish V. I believe that is the correct range, but it is happening in the wrong direction.
Any guidance there? I wanted to check before I buy a different part.
Old Jul 8, 2024 | 08:50 AM
WONKEY's Avatar
WONKEY
That is the correct voltage range for a TPS, did you replace the tps? If you did, where did you purchase it from? Do you still have the old one if you changed it?
Old Jul 9, 2024 | 04:20 AM
TimHixson's Avatar
TimHixson
I bought the bike at auction. It had the wrong one on it already. Looks like Harley has this part on back order til september. Trying to fine one now. Part 27629-01A
Old Jul 9, 2024 | 06:22 AM
WKNDS's Avatar
WKNDS
Here is one.
https://cv-performance.com/harley-th...ensor-27629-01
hth,
T.
scottiedawg
Jul 27, 2016 09:53 AM
kjkustoms
May 29, 2014 07:45 AM
09rkpolice
Feb 9, 2013 08:03 PM
BBQHOG
Jan 8, 2013 11:10 AM
PappyUSMC
Oct 9, 2012 09:16 AM
