hi guys, the diag of my bike does not open and consequently I can not see error codes, just as the speed pointer does not work, I've already reviewed the speed sensor and there's nothing wrong with it. Anyone have any idea what it can be?
you are holding the odo button on the back of the speedo before turning the key? And continued until diag begins?
are there any lights or display in the speedo?
yes, i hold the odo button and turn the key, and diag continued not run. all light on displey is ok, trip a and b is ok, bean light, turn lights, fuses, all ok.
It seems that only the diag does not run and the odometer pointer
hi guys, I changed my speedometer with a friend to test and my speedometer worked normally on his bike and his speedometer that was ok did not work on my bike, so the problem of my not opening diag was not the speedometer, I'm still trying to find out what It's wrong with my bike,
