Having some issues could use some advice
Old Mar 24, 2018 | 05:19 PM
Derricklw's Avatar
Derricklw
Stage I
Default Having some issues could use some advice
When i squeeze my clutch my highbeam comes on when i let off clutch goes back to low beam.. Anyone have an idea of what could be going on?
Old Mar 24, 2018 | 08:20 PM
Kenny94945's Avatar
Kenny94945
I bet it is a pinched wire.
Or the switch assembly is loose/broken.
Remove the handlebar switch assembly and have a look.
Good luck.
Old Mar 24, 2018 | 08:24 PM
Iceman24's Avatar
Iceman24
Any recent handlebar, grip, and/or wiring mods?
Old Mar 24, 2018 | 08:36 PM
Grey_Beard's Avatar
Grey_Beard
I believe Kenny94945 hit the nail on the head. OP seems too perplexed at the symptom, and not knowing the cause.
Old Mar 24, 2018 | 08:45 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Welcome to the forum. Take the time to properly introduce yourself and provide the year and model of your motorcycle. Think about when the issue started and what you did prior to the problem starting.
Old Mar 24, 2018 | 09:24 PM
Johnnyh14's Avatar
Johnnyh14
I would agree with the other posts and check for pinched switch wire. No problem with the horn or left signal which would be in the came cable group?
13RoadKing
Electrical/Lighting/Alarm
15
Apr 4, 2017 10:27 AM
fffffish
Apr 14, 2016 05:27 AM
maxboxa
Apr 30, 2013 05:06 PM
bikereef
Oct 29, 2007 10:43 PM
jose409
Nov 25, 2006 02:03 PM
