Electrical issues
Old Dec 30, 2019 | 08:34 PM
IrishHick1776's Avatar
IrishHick1776
Originally Posted by RANGER73
Bad stator killed the voltage regulator and the first battery.
even with a bad regulator, a new battery should still start the bike. My understanding is the regulator regulates the voltage from the stator to the battery.
Old Dec 30, 2019 | 08:48 PM
RANGER73's Avatar
RANGER73
Did you charge the "NEW" battery or get it off the shelf and install it?
And if the VR is trying to deliver 14 volts for too long that it's not getting from the stator it cooks itself.
Old Dec 30, 2019 | 08:57 PM
IrishHick1776
I get the regulator is possibly cooked. I’m trying to figure out why the bike won’t start for now. That was off the shelf. It’s sitting on the charger now. This is the 4th battery I’ve had this issue with, and they’re from two different shops. The odds of having 4 bad batteries in a row is unreal. Off the shelf the voltage reading was 13.89Vac.
Old Dec 31, 2019 | 08:52 AM
stereoguy's Avatar
stereoguy
Did you really check the cables? This is what I found under the insulation, the ground is notorious for being broken under the insulation at the motor.
Old Dec 31, 2019 | 11:56 AM
HOTLAP's Avatar
HOTLAP
Only thing I can think of is something in the stator/clutch area is binding up, if you take the side cover off and loosen the primary adjuster all the way can you rock the clutch/ring gear back and forth?
Old Dec 31, 2019 | 06:41 PM
IrishHick1776
checked and cleaned was he first thing i did before pulling off the cover and checking the internals.
Old Dec 31, 2019 | 06:45 PM
IrishHick1776
it all moves. I pulled the cover off last night before posting again. The battery doesn’t seem to have the power to turn the motor over. The starter gear doesn’t always engage, but once it’s lined up, it won’t have enough power to turn the motor. Twice the starter gear has gotten stuck, but with a little help it slides back in (it sounds a little rough). Nothing is binding up until I try to start the bike. I’ve taken a cheater bar and socket and have cranked the motor by hand, bike in neutral, everything moves. My old man thinks it’s a battery issue, but 4 bad batteries doesn’t sound right to me. I charged battery 4 over night, sitting at 13.05Vac, gonna give it a shot, but I have no expectations.
Old Dec 31, 2019 | 07:26 PM
HOTLAP's Avatar
HOTLAP
Try swaping the system and start relays in the fuse box, they are both the same and interchangable.
rcoleman1701
Apr 10, 2013 09:27 AM
locodude
Aug 9, 2011 03:12 PM
rekesbass
Sep 12, 2010 12:24 AM
ADS0105
Jul 18, 2010 01:59 AM
locoman77373
May 25, 2006 01:18 AM
