Jet sizes
Old Feb 8, 2022 | 09:37 PM
Acrodave22's Avatar
Acrodave22
Default Jet sizes
Can anyone tell me what the actual size is of a #48 slow jet in a CV carburetor? My guess is that it might be .048 inches, but it might be something in a number drill, or something metric. I am a machinist, and have almost every size of tiny drill you can name, but I don't know what the jet numbers represent. Specifically, my carb seems to run a little lean with a #45, and I would like to simply drill it out to become a #48, but I don't know what decimal size that is. I would simply buy a jet, but I can't get one until monday. I have another jet out of a carb rebuild kit, but it isn't marked (it figures!). I'm going to try to measure the #45 I have, and see if the unmarked one is larger. If it is, I might try it or if it is smaller, I might try drilling it out a few .001. I would sure feel better if I knew what diameter a #48 was supposed to be.
Thanks
Old Feb 8, 2022 | 09:53 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Everything you need to know about CV carbs, jetting and getting them to run correctly is here: http://sportsterpedia.com/doku.php/techtalk:evo:carb02
Here are the sizes from one of the pages.
Old Feb 8, 2022 | 10:03 PM
Acrodave22's Avatar
Acrodave22
That is EXACTLY what I needed......... Thanks a bunch!!!!
Old Feb 8, 2022 | 10:10 PM
CoolBreeze3646
YW, do not forget to go to: http://sportsterpedia.com/doku.php/techtalk:evo:carb02 and read about jet sizing and how to dial in the CV so it runs correctly, may not need a larger jet size, maybe only tweaking the needle etc.
Good Luck and Best Regards.
Old Feb 9, 2022 | 07:55 AM
John Harper's Avatar
John Harper
I have a real Keihin #48 on the shelf, PM your address if you want me to mail it to you.
John
Old Feb 9, 2022 | 08:31 AM
TexasScooterTrash's Avatar
TexasScooterTrash
A 1200 or 883 should run good with the 45 jet. Try adjusting the mixture screw first. If not satisfied, lift the e clip on the needle.
Old Feb 10, 2022 | 01:43 PM
Gary1's Avatar
Gary1
Get a velocity performance needle from cv performance. Mine runs great with it.
I have 170/45 jetting.
Old Feb 10, 2022 | 03:47 PM
Acrodave22's Avatar
Acrodave22
John
Thanks. I found one, believe it or not just .6 mile from my home. I installed it, and the engine seems to be running perfectly so far.
intensecombat
Carburetor Related
Apr 19, 2015 08:20 PM
j404ski
Shovelhead
Mar 22, 2010 07:45 PM
aa961jester
Exhaust System Topics
Aug 27, 2007 08:51 AM
outfishin35
May 30, 2007 12:19 PM
Gadgetech
Aug 27, 2006 03:35 PM
