Coil wire routing
Old Sep 10, 2022 | 12:46 PM
HDRIDER7's Avatar
HDRIDER7
Default Coil wire routing
I was looking at my buddies 05 sportster and noticed the coil wires are routed a bit differently than my 07. He had clips holding the coil wires where the horn bolts to and mine are missing. Also i have a short coil wire that is going to the front cylinder where his wraps around under the gas tank and goes to the front cylinder. Also my rear coil wire is laying across the cylinder head which i dont think is right. Both of my coil wire clips are missing from the horn bracket. Does anyone have a schematic or picture of where to properly route these wires?
Old Sep 10, 2022 | 05:23 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
You can use this link to look up every part on your Sporty. Just choose the year and model, then browse all the different diagrams, with part numbers and descriptions.
https://shop.suburbanharley.com/oem-parts
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Sep 12, 2022 | 09:11 PM
cncmike's Avatar
cncmike
Here is how my 2004 looked from the factory. Below is how the parts catalog shows it so that is no help. The clips aren't sold separately, you have to buy the whole wire. Someone might have put wires from a bigger bike on it.
Old Sep 12, 2022 | 09:16 PM
cncmike's Avatar
cncmike
It looks like I gave you some bad information. I thought you had the 2005 which is the parts list I showed you above. You have the 2007 which is fuel injected and does have completely different plug wires and not clips. Your friends bike is carburated. It looks like what you have is correct.
Old Sep 13, 2022 | 07:18 AM
TexasScooterTrash's Avatar
TexasScooterTrash
Comparing spark plug routing between an 05 carb and an 07 EFI bike is like comparing apples to oranges. The spark plug cable routing from Harley is just fine.
Old Sep 13, 2022 | 03:04 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
The ignition coils have totally different part numbers on 2005 and 2007 Sportster models.
2005 : - 31655-99.
2007 : - 31656-07.
Old Sep 14, 2022 | 06:09 AM
HDRIDER7's Avatar
HDRIDER7
I see that the coil wires are correct thank you for the info. But is the rear coil wire supposed to be laying across the cylinder head? Seems like over time its going to burn through
Old Sep 14, 2022 | 06:58 AM
Rob Roy's Revenge
Don't worry about the heat damaging the HT leads, the outer coating is made from high temperature resistant silicone rubber, they won't burn through.
Old Sep 15, 2022 | 06:35 PM
HDRIDER7's Avatar
HDRIDER7
Changed the plugs today and i was wondering, are the plug wires supposed to audibly click onto the plugs? Mine just went on without any click or anything, they arent loose because they take force to pull off but im just nor used to this style of plug with the cap. Im used to the threaded style plug, if that makes sense
scubahsteve
Mar 16, 2016 03:56 PM
Schwann
Nov 14, 2014 01:04 AM
T-rat
Apr 3, 2013 12:55 PM
run_ride_hide
Dec 22, 2012 05:06 PM
gutz63
EVO
Jul 15, 2010 03:49 PM
