coldest start temperature
Old Mar 2, 2010 | 12:38 PM
mike33ca's Avatar
mike33ca
Default coldest start temperature
Whats the coldest weather you guys are able to get your sportsters to start in? obvioulsy I mean when stored outside? I know with my previous non-harley bikes anything within a few degrees of freezing meant it wouldnt start
Old Mar 2, 2010 | 02:49 PM
humpyy57's Avatar
humpyy57
Last winter my lousy van would not start at dead 0 but the bike fired right up after not being ridden for 2 weeks and no tender
Old Mar 2, 2010 | 04:15 PM
badger1984's Avatar
badger1984
I have a battery tender on mine and it started in January when the temp was 7F. I needed to get it running to take it in for work before we had tons of snow.
Old Mar 2, 2010 | 06:32 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Mine started at fifteen degree's this winter.
Old Mar 2, 2010 | 07:58 PM
eazyrider's Avatar
eazyrider
15 degrees here as well. She took a while but she fired.....and then quit....and then fired again. That was cold day, damn.
Old Mar 2, 2010 | 09:53 PM
WRAITH's Avatar
WRAITH
-15 C.(10F),parked outside over night,started first try.
Old Mar 2, 2010 | 10:36 PM
SportyPig's Avatar
SportyPig
Sitting outside overnight, the coldest I've started mine was 12 degrees.
I did start it once last winter with the temp at 0, but I pulled the bike in the hotel room that night. I don't think if would have started if I didn't.
Old Mar 3, 2010 | 08:15 PM
Stefan's Avatar
Stefan
I have always been able to borrow a garage for overnight in the winter.
After riding to work it then sits outside for 8-12 hours at temps below 20*F, in the sun. My coldest ride to work this year was 4*F, last year 9*F.
It will start after a couple of turn overs. The engine does not like it very much. The problem is the cold oil on the flywheel. I run either 20W50 or straight 50 weight oil. It would start better if I changed to a lighter weight oil as recommended in the manual.
I do not use a battery tender or charger.
ron@creativesewingshops.com
Milwaukee Eight (M8)
38
Dec 29, 2023 10:24 AM
Ricekj
Mar 26, 2019 08:49 AM
Drat
Apr 1, 2015 07:17 PM
rnl_1200C
Jan 6, 2009 03:02 PM
billmc7
Mar 17, 2008 08:07 PM
