battery charging problems
Old Jun 15, 2010 | 07:38 PM
vet767's Avatar
vet767
Originally Posted by 1HD1C
are you making this statement from fact or just guessing?
personally i checked all connections but will not tear anything apart as you are at the will of the servicing dealer, i have been in that position with a new car dealer in the past and i dont want to give them any excuse to not service the bike under warranty
Fact Shortly after buying my 99 XLH the battery would not charge. Battery was new so I pulled out the manual and tested the regulator Showed to be bad. Called the dealer. They replaced it, no charge and the sporty was 9 years old, with 7000 miles on it. Haven't had a problem like that since. Trust them and have purchased two more great bikes from them 03 100th Anniversary FXDL and 08 RK Classic
Old Jun 15, 2010 | 07:41 PM
vet767's Avatar
vet767
Sorry Sporty Pig Did not see that it was cHarley that disagreed. Too much beer
Old Jun 16, 2010 | 03:16 AM
RebelBugler's Avatar
RebelBugler
Default 99 Sporty 1200 Custom w/bad voltage regulator
Interesting thread....I had an electrical issue as well on a bike with 6,000 miles! Battery would sometimes fail to power starter. Problem continued after replacing the battery. Checked things out with a multimeter and determined that stator was putting out plenty of current, suggesting that the voltage regulator was bad. Replaced the Voltage regulator and now everything works fine.
Old Jun 17, 2010 | 12:31 PM
Dynamic's Avatar
Dynamic
Default Regulator problems
The late model HDs have three phase alternators, consisting of a stator (stationary windings bolted to the crankcase) and a rotor (half dozen permanent magnets glued to a metal dish which rotates on the left end of the crankshaft). Imagine three separate alternators with the positive and negative peaks of the sine waves occuring at intervals of 120 degrees of rotation.
The third main component is the voltage regulator and rectifier which bolts onto the frame ahead of the engine. It converts the three AC inputs (which are phase shifted) to a relatively smooth DC output and then regulates the voltage of that DC output to be compatible with the operating voltage of the fourth main component, the battery, or approximately 13.8-14.2 volts. So, it's a fairly complicated bit of electronics and depends on being able to radiate waste heat to the atmosphere. This is why chrome covers are a bad idea, like wrapping the Regulator/Rectifier in a blanket.
The alternator is relatively simple. Essentially three long pieces of wire each wrapped around four pole pieces, twelve total. One end of each of these wires is joined to the other two, joining them electrically. The other ends exit as the three AC leads. As the rotor's magnetic poles pass by these windings, they induce current to flow in the stator. If the Rect./Reg. is doing it's job, the output from it charges the battery, or just passes a little through (due to internal resistance of the battery) with the rest running the system--if the battery is fully charged.
The problem is that the diodes (one way valves, sorta) which accomplish the conversion from AC to DC can fail in two modes. Open, in which case it takes out at least one phase of the alternator, or shorted, meaning that the stator becomes the load. It heats up, increasing the resistance and that leads to more heating which further increases the resistance........you see where this is headed. This can also happen if the DC outputs are shorted together before any other load is supplied, like the battery or the rest of the electrical system. It was relatively common on the older (single phase) bikes to short at the plug where the stator plugged into the wiring harness. More common with the Big Twins, being right up in front where all the rain and goo would hit it.
There has apparently been a rash of Reg./Rec. problems in the Dynas, too. I found out about it on some blogs and so carried a spare along with the allen wrench to change it, on my recent mainland trip. I didn't need it.
Old Jun 17, 2010 | 12:57 PM
SportyPig's Avatar
SportyPig
I've lost 2 stators and 2 voltage regulators.
Old Jun 17, 2010 | 01:08 PM
Dynamic's Avatar
Dynamic
If your alternator stator goes, ask to look at the plug on it and on the wiring harness. If the pins look corroded, dirty, or burnt, suspect some contamination, probably water, in the plug. One of the dangers of frequent washing or riding in the rain.
Old Jun 18, 2010 | 08:56 AM
Cpitch's Avatar
Cpitch
i just got my bike back this week. it was the voltage regulator. good to go now.
Roni
Aug 5, 2024 05:13 AM
HDJIM1158
Aug 16, 2014 01:37 AM
WOLFE1584
Mar 12, 2013 01:13 PM
WOLFE1584
Mar 11, 2013 05:57 PM
Sledriver
Apr 1, 2007 08:40 PM
