Big rake, stretch needed?
I haven't decided if I'm going to do it or have someone do it yet, though I'm leaning towards the latter due to limited welding equipment on hand. Unfortunately, my TIG is still sitting at the manufacturer's, they don't want to send it to me till I pay for it, go figure
and all I have on hand is a 120v MIG. Yes, I know it'll handle it if done right, but still...I'm just looking at the neck construction on this 84 ironhead and I'm not sure how easy a stretch would be, mainly the reorientation of the downtubes.
Experience? Thoughts from those who have done these?
Usually I will start with the frame, modify it as I want then shop for an appropriate front end but if there's a specific front end I want to run (like it seems you are doing) then I'll mock up the front end & wheel until it's sitting with proper trail...like this
This will tell me the rake I will need and from there I can measure the neck location to the floor, subtract the ground clearance I want and compare that to stock dimensions. That will tell me how much "up" I need. The "out" is subjective to your liking but, for me, it is usually half of the "up" added length.
I've read quite a few of your posts and respect your input, at what point would you call it too much trail? This is going to be a bar hopper (note: I don't drink when riding, ever, not even a beer) so it will be ridden quite a bit, only time it'll be on a trailer is stolen or broke down, but it also won't be doing multiple hour runs. To an extent, this bike will be more form than function, but must remain functional. Normally, I'm all about function and form is an afterthought.
Reangle the neck to account for trail. Add "up" to put the lower frame rails where you want them with the long front end (parallel with the ground, 3 of 4 degree slope to the rear, whatever).
If you plan on just cruising around at somewhat rational speeds and often negotiating parking lots, trail will be important. Trail issues are exposed at low & high speeds.
The rule of thumb of proper trail is 4-6" but 3-7" has always been a good range for me.
I usually build with springers so I have to set everything by the frame and sometimes by manipulating the rockers.
