Starting problems
Old Feb 6, 2007 | 06:18 PM
ROADTRAIN's Avatar
ROADTRAIN
Default Starting problems
A friend has a 07 1200 Sporster that will not start. She has power as in lights, but nothing at the starter. The problem was given over the phone so not alot of information available. Maybe someone has had a similar problem. Also unable to get to a dealer.
Old Feb 6, 2007 | 06:33 PM
DaveJ's Avatar
DaveJ
Default RE: Starting problems
As you said, not a lot of info. But if the lights are on, I will assume the key is in the ignition, all the way forward. The 07 has a neutral start switch, so it needs to be in neutral or have the clutch engaged. Does it have the security system? If so, is the key fob within close proximity?
Old Feb 6, 2007 | 06:38 PM
ROADTRAIN's Avatar
ROADTRAIN
dj, thanks for your help, I will relay the info about the neutral start switch, she may have overlooked the bike being in gear.
Old Feb 6, 2007 | 06:43 PM
DaveJ's Avatar
DaveJ
No problemo. I hope that's all it is!
saltlick's Avatar
saltlick
man i wish my bike had that neutral safety feature. I got use to it on my other bike, tried to be cool and show my friend my new harley, pushed the start button in first gear, learched forward and barely kept the bike upright.
Old Feb 7, 2007 | 09:45 PM
ionate's Avatar
ionate
I'm glad that I'm not the only one who has done that before! The bike jumped and made me jump... looked like a total **** I'm sure.
Old Feb 8, 2007 | 01:03 PM
PSUBIKER's Avatar
PSUBIKER
Check the kill switch.
Old Feb 9, 2007 | 12:12 PM
TEK 679's Avatar
TEK 679
Another thing to check that is pretty basic is the ground conection on the battery if it is loose you will still have lights ect but starter may not engauge.
stbob07
Sep 11, 2012 09:16 PM
NHHog
Mar 12, 2012 08:32 PM
RyKR
Apr 22, 2010 02:09 PM
MassHD
Nov 1, 2008 07:08 PM
Ragin_Republican
Mar 30, 2005 02:48 AM
