1200c riser question
Old Apr 1, 2014 | 10:41 PM
jhamm's Avatar
jhamm
Default 1200c riser question
I know it has been discussed and I have researched w little success.
Just got '12 1200c. It has 14" apes on the stock riser. I don't hate the look as many others seem to but I would prefer straight risers.
Straight riser options?
Has anyone had any made?
Speedo relocation options?
Thank You
Old Apr 2, 2014 | 09:02 AM
jhamm's Avatar
jhamm
no one?
Old Apr 2, 2014 | 09:11 AM
Chad1200's Avatar
Chad1200
I switched to the standard Sportster speedo housing/riser clamp with a set of straight risers. It came of a Nightster if I remember correctly. If you go this route, you'll need to switch the indicator light display as well. I don't have the part numbers but they're not hard to find.
Old Apr 19, 2014 | 09:08 AM
ColinXL1200's Avatar
ColinXL1200
6th Gear
Default cables
Hey chad did you buy a cable kit or did you custom order each cable.
Old Apr 19, 2014 | 02:42 PM
AjaBra's Avatar
AjaBra
Cheapest and easiest is to swap with a low. Guide I wrote a while ago: https://www.hdforums.com/forum/sport...nd-photos.html
Old Apr 19, 2014 | 08:34 PM
DocCecil's Avatar
DocCecil
Its all about look. What setup you like the best. You can use the nightster/iron setup, low, buy risers and shave them to fit 48 top clamp, or use a flat top clamp and relocate your speedo setup to a side mount. Its just what look you are after. Each one sits a little different. To change the indicator lights you just take apart the one on your bike and disconnect/cut wires, buy nightster style indicator lights and solder them on. Its pretty easy.
Old Apr 29, 2014 | 10:59 AM
Chad1200's Avatar
Chad1200
If I remember correctly, the clutch cable is from Drag Specialties. I ordered Drag Speciaties throttle/idle cables as well but they only lasted 2 years so I eneded up using stock take-off cables from a buddy's 2012 Wide Glide. The existing brake line worked fine...just had to take the bends out of it.
roadkingkat
May 15, 2012 07:36 AM
JerryDinMD
Mar 16, 2012 06:14 PM
Scottybob
Jul 7, 2011 07:56 PM
County98
Apr 5, 2010 12:55 PM
chromedome
May 12, 2008 10:51 PM
