oil leak
Old Mar 29, 2007 | 02:50 PM
gwilson3645's Avatar
gwilson3645
1st Gear
Default oil leak
Hello,
This is my first post here, I have an XL883 2007 bike. Just have 150 miles on it so far and I have a small oil leak on the rear cyclinder, rear bolt, on the left side. It is very small, looks like a drop or two around the bolt head. Is this kind of normal or maybe retorque the bolt, take it to the dealer, or is this just normal. Any thoughts.
Gene
Old Mar 29, 2007 | 02:52 PM
jakedog's Avatar
jakedog
Default RE: oil leak
It's under warrenty; take it back....IMHO
Old Mar 29, 2007 | 03:09 PM
dhc8guru's Avatar
dhc8guru
On my 07' 1200N,it gets some small amounts of oil residue around the shift lever and the starter.. undoubtedly oil vapor working its way out of the engine. I expect this on an aircooled engine..no worries.
Old Mar 29, 2007 | 03:33 PM
cHarley's Avatar
cHarley
ORIGINAL: jakedog
Ditto, and Welcome, if it's small don't worry but have it corrected at the 1K service under warranty. That will save aa extra trip to the stealer.
Old Mar 29, 2007 | 04:02 PM
GothMetalGuitarist's Avatar
GothMetalGuitarist
ORIGINAL: gwilson3645
Hello,
Gene
Chrome Rocker covers leaking? I believe there was a recall on some of these for warping in2007. Either way stealer should fix for free.
Old Mar 30, 2007 | 10:39 AM
gwilson3645
1st Gear
No, just the chrome head bolt. I'm wondering if there is a o-ring under the shoulder that could be replaced, if so could the bolt be removed by itself without damage to the head. I have a BMW R1100RT and to adjust the rockerarm slack, one head bolt must be loosened forthis adjustment, it seems to be ok for BMW. I haven't aquired a service manual yet. As for taking it to the dealer, only for a major problem that I wouldn't feel comfortable with. I still change oil and tires, I'll continue as long as I feel like doing it. Anyway, the engine is sealed up pretty good so far after 200 miles, other than this bolt.
Gene
_____________________________
Old Mar 30, 2007 | 11:04 AM
883Sporty's Avatar
883Sporty
Take it back and have them fix it. All HD's are prone to being a bit leaky. Not to say that ALL HD's leak, but mine did a little. My issue is mostly blow-by. I had my mechanic re-route the hose. It was hard for me to accept that whenI got mine. I came from metrics that never leaked unless something was seriously wrong. It's just part of owning a Harley.
Old May 21, 2007 | 01:36 AM
utexasrider's Avatar
utexasrider
did you ever fix this leak? it seems like i have the same problem.
trackadaptor
Feb 26, 2013 09:32 PM
les63
May 23, 2009 09:05 PM
Curlingace
Dec 29, 2007 11:28 AM
soft 02
Jun 26, 2007 12:08 AM
stevegray
Sep 12, 2006 09:16 PM
