"The Florida Crew" Rides and Information From The Florida Crew.
bike is temp down for now
Old May 17, 2009 | 04:07 PM
bulldogmoe7's Avatar
bulldogmoe7
Default bike is temp down for now
cant do any long distance riding for now. i think the NC trip did it for her.
i posted my question over in the "touring" section about this. to get an answer.
speedo
today went over to screamin egos fort to check out ladyhawks NEW ride. on the way over the speedo dropped out again. even after that short ride. on the way home it dropped out again and this time the idle dropped down to about 500rpm
but it soon came back back, NOT NORMAL. pulled into the garage, left it running to "find" the issue and it started to sputter.
so till i find this issue long rides are down. back and forth for 10min to work isnt a big deal since itdoesnt get hot enough to cause issue. so hopefully by this weekend i can get a resolution on my own before i spend mega bucks for the dealer to find.
Old May 17, 2009 | 04:19 PM
masterblaster's Avatar
masterblaster
Trade it for an 09.
Actual response in the touring section.
Old May 17, 2009 | 04:33 PM
bulldogmoe7
that's definitely a bug going around for the '09
Old May 17, 2009 | 04:50 PM
1of2's Avatar
1of2
"Moderator"
"Made it mine in 09"
Old May 17, 2009 | 05:01 PM
cHarley's Avatar
cHarley
Check for any stored DTC's (diagnostic codes).
Old May 17, 2009 | 06:28 PM
bulldogmoe7
it pulled this code
P0501 VSS Low EFI
VSS - Vehicle Speed Sensor. Used as an input for idle speed control
Old May 17, 2009 | 06:38 PM
Phlip96's Avatar
Phlip96
I dunno bout this new way of thinking? what happened to the ol timers that would fix their own shovelheads and wrench their own scoots instead of just 'trading' in for a new model?
Oh yeah, I know, they make the bikes so damn complicated now, You get so frustrated trying to find the problem in all the computer crap on board now.
Old May 17, 2009 | 08:19 PM
2of2's Avatar
2of2
Get a new one Bulldog, before the dealers run out of bikes in Florida!
Old May 18, 2009 | 07:59 AM
BlueDragon's Avatar
BlueDragon
Wow... this issue is becoming a very serious one~ Hope you get it figured out and repaired soon~ Sucks that stealership up north charged you a pretty penny only to get down the road and have it become a bigger problem~
You could always do like I did... trade it up for the wife's bike... then YOU can ride biotch!
Old May 18, 2009 | 11:24 AM
Bertk's Avatar
Bertk
Replacing the speed sensor is the first step.
Next step is to start looking for loose, broken or dirty wiring.
You mentioned the appears when switching from low to high beams. This may be a good place to start. Try to repo this by clearing all codes and switch from low to high beam. Then check for codes. Also check any other electrical add-ons that have been installed.
Here are some areas that others have found wiring problems that cause what you are seeing.
Battery terminals
Bad ground - Anywhere - The service manual would be very helpful here.
Neutral safety switch
Bank angle sensor
Bad or blown fuses
Ignition switch
Handlebar controls
Voltage regulator
Wiring harness – one way to check this is to clear all codes, start the bike and rotate the handlebar full right and left looking to repo the speedo problem and codes. Another way is to remove the outer fairing and start wiggling wires. And in your case, switching from low to high beam.
Good luck.
