Crankcase threaded holes
Old Oct 1, 2014 | 08:08 PM
thomasjpt8's Avatar
thomasjpt8
Stage III
Default Crankcase threaded holes
I have a 2013 Ultra. I was cleaning the bike up today (oil airfilter blowby had run down the right side) and noticed two threaded holes in a milled out flanged area on the bottom right side of the crankcase, directly above the frame. I can't seem to find anything on this forum that addresses this, or what normally goes there, or what it's for. A shop manual is on the to do list, but any insight would be appreciated.
Someone in a post had made a reference to freeze plugs being in this general area, but without a manual I cannot confirm that. I basically just want to make sure that something vital hasn't rattled off, which I would be hard pressed to believe that two bolts wiggled free...and as a daily rider i haven't noticed anything different.
thanks!
Jessie
Old Oct 1, 2014 | 08:11 PM
Bill03E's Avatar
Bill03E
How about a pic?
Old Oct 1, 2014 | 08:19 PM
thomasjpt8's Avatar
thomasjpt8
Stage III
I know it doesn't look like it, but I'm pretty sure the oil is coming from the air filter, which is the whole reason I was in this area to begin with...
Old Oct 1, 2014 | 08:23 PM
Jackie Paper's Avatar
Jackie Paper
If I am looking at that correctly, that is a drain hole for the cam case separate from the crank area(except thru the main bearing) for checking to see return side of the oil pump is OK if a sumping condition is indicated. It is a NPT tapered plug. It is very easy if you over tighten to break case, so it's best left alone. If not use sealer, and after it bottoms, a little more. The reason the cam case is separate from the crank area is for proper venting on a twin cam.
Old Oct 1, 2014 | 10:35 PM
SeaZund's Avatar
SeaZund
[QUOTE=thomasjpt8;13276689]I have a 2013 Ultra...Someone in a post had made a reference to freeze plugs being in this general area, but without a manual I cannot confirm that. QUOTE] are you serious? on an air cooled engine?
Old Oct 2, 2014 | 06:37 AM
lp's Avatar
lp
I have no idea what would go there but my 09 has the same stuff in the same place.
Nothing is attached to it. So.... normal I guess.
Might be something that is used in another platform like a dyna or something. No biggie.
Old Oct 2, 2014 | 06:52 AM
Scrmnvtwins's Avatar
Scrmnvtwins
look at the H-D engine stand, maybe these are the tapped holes to mount the cases to the stand......
Old Oct 2, 2014 | 07:29 AM
Max Headflow's Avatar
Max Headflow
Those holes (3 actually) are for an exhaust bracket on the Dyna models.. Dyna models mount the whole exhaust system to the motor / tranny...
Old Oct 2, 2014 | 07:44 AM
SafetyMan's Avatar
SafetyMan
Originally Posted by SeaZund
Originally Posted by thomasjpt8
...freeze plugs...
Beat me to it....
I was going to ask what may freeze....
Old Oct 2, 2014 | 11:09 AM
BJB's Avatar
BJB
Exactly, Max.
Now OP; Why are you retaining the umbrella drains into the A/C and gunking up the throttle body and adding carbon to your valves & piston tops?
brc0703
Dec 10, 2018 10:25 AM
rinja64
Oct 6, 2015 11:03 AM
619er
Oil Archive (no new posts)
Nov 15, 2013 01:06 PM
IM2FA5T4U
Jun 17, 2013 09:19 PM
huffhuff
Jun 14, 2006 01:01 AM
