instant rocket!!!
Old Apr 12, 2007 | 09:39 PM
the big buck's Avatar
the big buck
Default instant rocket!!!
just installed andrews 37g cams, v&h dresser duals with thunderheader slipons, racetuner, on a stock88, with stock heads....dynoed at 91 horses 93 torque...gained 20hp, 21torque....very pleased.
Old Apr 12, 2007 | 09:55 PM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
Default RE: instant rocket!!!
what year bike?
Old Apr 12, 2007 | 10:33 PM
the big buck
06 eg stadard. i was concerned about pinging from what philm and others experienced but there is none...my wrench is an artist with the racetuner and dyno...in fact anyone out in so.cal and you need a good wrench let me know.
Old Apr 12, 2007 | 10:50 PM
fishafly's Avatar
fishafly
ORIGINAL: the big buck
I'd be interested in knowin'...
Old Apr 12, 2007 | 11:23 PM
PhilM's Avatar
PhilM
If ya didn't bump the compression above 9.5/9.6:1, you shouldn't have any ping issues and if the top end is untouched, then you have not...
Congrats! Gald it worked out for ya!
Old Apr 12, 2007 | 11:42 PM
the big buck
are ya saying that if i did headwork ping might be an issue?
Old Apr 12, 2007 | 11:53 PM
PhilM's Avatar
PhilM
Not necessarily.
If you exceed Andrews recommended compression ratio, for that cam, espically in a Bagger.... it will then be prone to pinging. Head work, in and of itself, does not always change compression ratio. Your wrench will now how to give ya what you (and it) need. You can have head work (with or without 95" pistons) and build it for any desired compression ratio.
Keep your target CR @ 9.5:1 and you'll be fine.
Many try to squeeze more power out of them by increasing CR just a bit and that's when ya run into problems. Since that cam is "designed" for a lighter bike, you do not have as much margin for error when you use it in a heavy bike.
....again, just my experience....
Old Apr 13, 2007 | 12:59 AM
GasCan's Avatar
GasCan
Do you normally pick much up off just the cams alone? Always seemed a waste to me to do cams without doing the top end since the latter happening down the road usually requires bigger cams than one would initially install without the head work. I'd just hate to do it twice in case I added heads or jugs down the road. You know your gonna want more later....right?
Old Apr 13, 2007 | 01:13 AM
04RoadKing's Avatar
04RoadKing
WOW[sm=jawdrop.gif]
Old Apr 13, 2007 | 01:49 AM
DrLove907's Avatar
DrLove907
Nice Job, soon as I save some money I will be doing something similar as my winter project.
