Brake bleed problem
Old Oct 30, 2014 | 07:19 PM
skiddd's Avatar
skiddd
It helps tremendously thank you. I will do this tomorrow morning................. thanks again Man...........
Smokey Stover's Avatar
Smokey Stover
+1 for Speed Bleeders, Pumped a whole bottle of fluid 1/2 left,right. And 1/2 abottle through the rear to flush/change fluids along with new pads in less than an hour. The manual says its OK to bleed normaly as long as you don't disconnect lines and get air in the system,But it can be flushed out as long as you dont turn on the ignition(I pull the main fuse just in case)
Old Oct 30, 2014 | 07:21 PM
skiddd's Avatar
skiddd
Pull the fuse, I will do that for sure. I can see myself turning the ignition on like an idiot!
nine11c2
18
Jun 27, 2020 12:33 AM
1Fordman
Jun 14, 2017 06:11 PM
rstekeur
Feb 16, 2014 02:19 PM
skully1200
May 11, 2013 03:37 PM
Romark
Nov 10, 2011 03:30 PM
