Need some help
Old Nov 7, 2014 | 09:44 AM
Reece64's Avatar
Reece64
Default Need some help
How can you tell if your front rotor is warped. Bike shakes at low speeds. I tried everything else from checking the neck to having tire rebalanced.
Old Nov 7, 2014 | 10:32 AM
mkguitar's Avatar
mkguitar
a dial indicator is used to check for warping.
or you can make a fixture with a pencil the tip just shy of touching teh rotor, turn the wheel slowly and see if you get pencil marks showing high spots...the low spots unmarked
or you can take off ( new bolts needed for reinstall) and place on a sheet of glass- measure around the edges with a feeler gauge.
Mike
Old Nov 7, 2014 | 10:36 AM
Hogpro's Avatar
Hogpro
Former Sponsor
And Harley's spec for rotors is .008" Usually the brake lever will pulsate when the pull the brake lever if the rotor(s) are warped. If it is bad the bike can shudder back and forth as it comes to a stop.
pdog75
General Topics/Tech Tips
Oct 7, 2016 10:08 AM
ToffeeBrown
Oct 12, 2015 04:07 AM
Lowside
Sep 22, 2014 11:11 AM
budlite282
Aug 11, 2013 08:05 PM
pirateheadman
Nov 3, 2011 10:26 AM
