Any body do cam install WO cutting pushrods
Old Dec 9, 2014 | 05:13 PM
Mr HOG's Avatar
Mr HOG
I've been using adjustables for years and never had one come loose. I would rather spend the extra money and save time and hassle. Your call. Just make sure you use the quickee SE adjustables. Regular adjustables won't clear.
Old Dec 9, 2014 | 06:03 PM
just plain john's Avatar
just plain john
It's not that hard. I did it having never done it before, and you can too. The key thing is to have the specific tools you need, and to go through the top you need dog bone wrenches to torque both the rocker arms down, then the covers, and if I recall correctly they are two different sizes. These are in addition to the cam tools. There are those who have successfully done it I suppose without using them. Your call on that one. The procedure is in the service manual.
Old Dec 9, 2014 | 06:41 PM
Sandcrab's Avatar
Sandcrab
Default Does this apply to mine also?
Originally Posted by dawg
Drill them out for better oil return
Dawg, I am currently working my way through a cam change, and saw the oil enlargement post. I just removed the front rocker cover, rocker arm support plate, both pushrods and both roller lifters. Does this apply to 09 Ultra classics with the 96ci motor? Any thing I need to do or know when doing this? My motor is stock with 49K miles.
Old Dec 9, 2014 | 06:58 PM
rkoivisto's Avatar
rkoivisto
Default Andrews
Originally Posted by Flhrhog
I was told they were the same, would you let me know what they tell you?
I talked to Gary at Andrews today. He said there is .02 difference in the base circle, but that .02 difference is fine. You can use stock PR's.
Oh, and Gary is a cocky SOB.
Old Dec 9, 2014 | 08:15 PM
dforeid's Avatar
dforeid
Originally Posted by OldEnuf2NoBtr
Depending on what cam you chose you may not be able to re-use the stock push rods so cutting them and installing a set of adjustables will save you a lot of time and work.
^^+1. It also allows you to run them down into the lifter a little more. Quieted mine down quite a bit.
micahpop
Dec 16, 2025 04:15 PM
barrygreen
Engine Mechanical Topics
21
Oct 17, 2017 09:41 PM
MichiganRider
Exhaust System Topics
Dec 6, 2011 07:23 AM
rm4040
Dec 23, 2010 04:34 PM
jpooch00
EVO
Dec 5, 2008 06:30 PM
