Air filter question
Old Jan 13, 2015 | 12:10 PM
StreetGlide515's Avatar
StreetGlide515
Default Air filter question
Have a stock 09 Street Glide with Screaming Eagle slip-on's and want to know if it is worth going to a high flow filter.
Just getting ready to change it out.
Thx!
Old Jan 13, 2015 | 12:15 PM
howitzer88's Avatar
howitzer88
Yes, but you should have the dealer flash the ECM due to the higher AFR. That is unless you decide on getting into an add-on tuning device.
Old Jan 13, 2015 | 12:28 PM
DresserDude's Avatar
DresserDude
Absolutely. More air is better, but as stated above, the bike is LEAN from the factory already due to EPA regs. You will need a tuning device to give the bike much more fuel.
Old Jan 13, 2015 | 12:31 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Thx!
Probably not unless you're also going to make significant changes to the intake, heads, pistons, and header.
FWIW, just about every stock air filter will flow more then your stock motor can draw. In most every case, a "high flow" filter will get you nothing but a hole in your bank account.
Yes, I know people really hate to hear that but it's the truth.
As to a tune...only a full-featured tune is worth doing. Unless you're going to set the VE's correctly to begin with, adjusting only the AFR is a complete waste of time.
Yea, I know, people don't like to hear that either...
Old Jan 13, 2015 | 12:34 PM
Leftcoaster's Avatar
Leftcoaster
The dealer flash is garbage.
If you do the air filter you will definitely need to re-tune. Find a good independent shop with a dyno cell and have it done.
You will like the results - you'll pick up an easy 10hp/10lbs ft. and still get great mileage.
Having an A/C that will flow more than the motor needs is a big plus. I know of no stock A/C that'll flow more air than your motor needs. Quite the opposite is true - due to EPA noise restrictions stock A/C's are all choked up right from the factory.
Freeing up air flow only makes sense and the motor will only flow what it needs.
Old Jan 13, 2015 | 01:24 PM
mkguitar's Avatar
mkguitar
Originally Posted by Leftcoaster
I know of no stock A/C that'll flow more air than your motor needs. Quite the opposite is true -.
Yes.
The stock air cleaner is restrictive for noise emissions, it also uses a filter media which becomes clogged and flows less.
Once the air has moved through the filter it has to make a 90ş turn into the throttle body.
The stock air cleaner flows about 160 CFM
Most aftermarket hi flow air cleaners incorporate an air horn into the backing plate, this will order the air and ease that 90ş turn.
Most have a better filter media
All are less restrictive- and noisier- some riders are confused by that.
Most aftermarket hi flow air cleaners flow 250 CFM or more ( which exceeds the motors demand)
with tuning compensation* adding a hi flow air cleaner to your pipes will get you 7 to 10 reliable horsepower out of your motor..getting you to the mid-70's.
I prefer the Ness Big Sucker which can be about $125 on ebay from easternpc.
that's the chrome backing plate version which looks best with the black/chrome motor.
This comes with an oiled, reusable, washable filter which will last a lifetime.
and this AC is an easier install that most.
*tuning compensation can be done with a variety of devices depending on the owners interest in exploring complexities and budget.
I use the plug in XIEDS modules from nightrider.com- cost about $125.
others use other devices which may cost more, may offer more, but may have drawbacks.
Mike
Old Jan 13, 2015 | 01:27 PM
mkguitar's Avatar
mkguitar
Yes.
Most aftermarket hi flow air cleaners incorporate an air horn, this will order the air and ease that 90ş turn.
and this AC is an easier install than others, the throttle body brace stays in place and the gas tank doesn;t need to be pulled, just loosened
Mike
Old Jan 13, 2015 | 02:04 PM
grbrown's Avatar
grbrown
As an alternative to IEDs I have a Dobeck tuner on my Buell, also simple to set up.
Old Jan 13, 2015 | 06:18 PM
qtrracer's Avatar
qtrracer
I get 153 cfm required for a 103" at 83% VE at 6200 rpm.
Old Jan 14, 2015 | 07:33 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
...Having an A/C that will flow more than the motor needs is a big plus...
And why do you say that?
A stock 103 TC at about 4000 rpm will flow approximately 135 cfm's. At about 5000 rpm, the cfm's "jump" up to about 143.
Here's MK's previous post...
Originally Posted by mkguitar
...The stock air cleaner flows about 160 CFM...
Of what value does an air cleaner that flows 250, 500, or even 1000 cfm's provide?
...due to EPA noise restrictions stock A/C's are all choked up right from the factory...
Seriously? Remove the air cleaner on a running motor and tell me just how loud it becomes? I dare say that unless a decibel meter is used, no one would hear any difference.
...Freeing up air flow only makes sense and the motor will only flow what it needs.
That last part is not exactly correct either. The motor will flow only the amount of air that is "allowed" based on the design of the entire system.
Here's a little hint that MIGHT help you understand air flow...there's a LOT of things that reduce air volume into the cylinders that's well after the air cleaner. I'm not saying the air cleaner plays no part but it's not what causes any significant increase in air volume if nothing else downstream is done to improve air flow.
For example, smaller port creates more velocity, which in turn creates more inertia. The principle of inertia is to pack as much into any given area before it stops. The more inertia, the more force it develops, and the more mass it will pack before it stops.
So, when you figure in inertia (velocity squared x volume or cfm), it becomes apparent that velocity is more important to cylinder fill than volume. And unless you've made significant mods to the intake, heads, pistons, and so on, you won't get any significant benefit from just going to a "high flow" air cleaner.
The marketing for all these "high flow" systems generally fail to mention that in order to take advantage of their bigger numbers, the motor has to be modified to the point is can begin to draw much larger volumes of air. It is far cheaper to manufacturer, market, and sell $125 systems then it is to sell $2000 mods to take advantage of that new air cleaner.
