A little bit different lighting question
Old Feb 27, 2015 | 01:53 PM
mkguitar's Avatar
mkguitar
You are correct on paper, but we use nominal 12 volt ratings as standard for the battery, wiring and the loads on the circuits.
Mike
Old Feb 27, 2015 | 02:33 PM
Buelligan666's Avatar
Buelligan666
The fuse shouldn't be run at more than 75% of it's rated load, and must be derated for ambient temperature.
From the Littelfuse Technical library "Introduction to Circuit Protection"
NORMAL OPERATING CURRENT: The current rating of a fuse is
typically derated 25% for operation at 25°C to avoid nuisance blowing.
For example, a fuse with a current rating of 10A is not usually recommended
for operation at more than 7.5A in a 25°C ambient. For
additional details, see RERATING in the previous section and
AMBIENT TEMPERATURE below.
VOLTAGE: The voltage rating of the fuse must be equal to, or
greater than, the available circuit voltage. For exceptions, see
VOLTAGE RATING.
AMBIENT TEMPERATURE: The current carrying capacity tests of
fuses are performed at 25°C and will be affected by changes in ambient
temperature. The higher the ambient temperature, the hotter the fuse will
operate, and the shorter its life will be. Conversely, operating at a lower
temperature will prolong fuse life. A fuse also runs hotter as the normal
operating current approaches or exceeds the rating of the selected fuse.
Practical experience indicates fuses at room temperature should last
indefinitely, if operated at no more than 75% of catalog fuse rating.
Old Feb 27, 2015 | 03:11 PM
Frank the Real Biker's Avatar
Originally Posted by mkguitar
*watts is not a true measure of light output - Lumens is.
** #881= 25w, #896= 37.5W, #886= 50W
Link to a website that has some interesting calculations about lumens. Just scroll down a page or two for the chart.
I left my headlight circuitry alone, but I upgraded my aux lights system by using a set of relays that go directly to the battery...via a fuse, of course. Now I have full voltage to them. Anywhere from 100 to 200 lumens brighter.
YMMV
Old Feb 27, 2015 | 03:25 PM
mkguitar's Avatar
mkguitar
depending on model year the results will vary from amazing ( my Evo to which I added relays for each spot, low and high beam) to marginal ( 2009) to none ( the Canbus bikes).
Nice stuff to run through the noggin.
i have a couple of 6 volt bikes, so I am always working on something...!
Mike
Old Feb 27, 2015 | 09:44 PM
Mike
Yup. Mine is a 2005.
Old Feb 28, 2015 | 11:26 AM
usraptor's Avatar
usraptor
I purchased a pair of Sylvania SilverStar ULTRA Headlight bulbs for my RGU from Walmart and they work great. The thing I like most about them is that they are considerably brighter than OEM so other driver's see me better and know I'm there. They also light up the road better. Good alternative at a reasonable price.
Old Feb 28, 2015 | 11:57 AM
FinalShot's Avatar
FinalShot
I agree with the logic above but that is not the only consideration to have. The actual size (gauge) of the wire and length of run needs to be determined as well and let's not forget about voltage drops.
I don't remember what size the wire is but if it is 16 awg, the system could probably safely handle a 20 amp load with the correct fuse based on wiring gauge calculations. If it is 18 awg, then that is out of the question.
Old Feb 28, 2015 | 12:06 PM
HDSAE60's Avatar
HDSAE60
I would use 13.8 volts for current theory.
RonaldL
Aug 15, 2016 09:54 AM
Perrysplus
Apr 10, 2013 05:47 PM
SE120RG
Jun 6, 2011 05:28 AM
pancakehead
Jun 3, 2011 11:11 AM
newarkknightweasel
Apr 16, 2011 10:16 PM
