A little bit different lighting question
Edit: I'm not sold on the LED lighting either. Too many complaints about dead spots. Especially in bends when you lean over. They are very expensive and everyone's solution to spending $300 plus on a headlight that is inadequate is to throw another $300 at additional lighting to make up for the shortcomings of the led headlight. I personally don't wanna drop $600 plus on lighting to replace the perfectly adequate stock lighting.
What he said.
with higher wattage bulbs* the service life is usually decreased.
the #896** 37.5W seems to be a good balance between light output*, power consumption, service life and heat (connectors and reflector).
2.) if you have the dual halogen, replace the H11 low beam with a H9 65w capsule- this requires a plastic tang be cut off
3.) I ( me) think that current led offerings are a hazard- add to the above concerns that the narrow beam spread makes riders less visible than they think. I will notice riders behind me on the hiway in my mirrors... as they draw close and get in the passing lane, the narrow light beam is no longer in my mirror.
I have also seen cars pull out of parking lots in front of bikes as the beam doesn;t shine to the side as much as we would think
led drawbacks are beam spread, hot/cold spots/ cost and for some colour temperature.
there is an advantage in power draw.
Mike
*watts is not a true measure of light output - Lumens is.
** #881= 25w, #896= 37.5W, #886= 50W
I went back to stock bulbs and everything went back to normal. I would suggest using the stock set-up.
or 4.92 + (55w x 2 lights) = 4.17 / or 8.33 = 13.25A
or 88% of the 15 amp circuit. vs the original design of 68% of fuse capacity.
I would say that as long as the battery was kept good then the circuit would be OK.
