Brakes & lock tight...?
Old Apr 13, 2015 | 01:34 PM
HDsportster99's Avatar
HDsportster99
Default Brakes & lock tight...?
After my ape hangers bike is running great. Went to bleed my brakes and realized its leaking at the triple tree. Im gonna drain the fluid and take it off and re-set it, but curious if i should add some lock tight, or will it get in the brake fluid and possible to the caliper ?? Thanks
Old Apr 13, 2015 | 02:54 PM
beary's Avatar
beary
General rule is no. Nothing should be added to areas that can get in contact with brake fluid.
Beary
Old Apr 13, 2015 | 02:55 PM
SBates08's Avatar
SBates08
I'm assuming that you have a 3-way junction block under the tree. Not sure about using loctite but in most cases if you've gotta leak there, tightening up the fittings should do the trick.
2010 Limited with some stuff
Old Apr 13, 2015 | 04:58 PM
petdoc94's Avatar
petdoc94
I agree, and I never use loctite on my brakes..
Old Apr 13, 2015 | 05:11 PM
HDsportster99
Thats what i figured. But still leaks ever so slightly
Old Apr 13, 2015 | 07:00 PM
just plain john's Avatar
just plain john
Maybe teflon tape or paste? Did you change the brake line?
Old Apr 14, 2015 | 05:32 AM
HDsportster99
Yes i changed the brake line. Actually foxed it yesterday, i used some tape and tightened her down. So far no problems
Old Apr 14, 2015 | 07:07 AM
Greezey Rider's Avatar
Greezey Rider
Thread locker and/or thread sealers such as Teflon tape shouldn't be needed on the brake system and should never be used.
If you have a leak, you need to find the source of the leak and replace the seals, O-rings, washers or whatever they used to seal the system from the factory to properly repair the system.
Old Apr 14, 2015 | 07:53 AM
Veekness's Avatar
Veekness
Shouldn't use any sealers or Loctite...the brake lines seal on the flange, NOT on the threads...if you have a leak, take a look in that area and address any problems you see there...they need to be snugged down fairly tight, BUT it is possible to over-tighten them too!
Old Apr 14, 2015 | 07:59 AM
bagman1's Avatar
bagman1
No sealers should be used. Brake line fittings are inverted flare and as said the sealing surfaces are the flange not on the threads. Make sure the line end is compatable with the block some may have different degrees of sealing surfaces. Like 37 and 45*.
stevek
May 30, 2018 12:52 PM
Krazyshark
Ironhead
Aug 31, 2012 10:13 PM
zworld
Jan 28, 2012 11:56 AM
ucadam
General Topics/Tech Tips
Mar 12, 2011 08:34 AM
chikenfat
11
Nov 2, 2010 06:37 AM
