slip ons with out rear mounting nut
Old Apr 17, 2015 | 08:41 AM
Timpechos's Avatar
Timpechos
Originally Posted by lp
What brand/model are they? Bet the manufacturer has a pdf parts list or installation guide that has them pictured.
There Klock Werks and I haven't been able to find anything from them.
Old Apr 17, 2015 | 08:53 AM
lp's Avatar
lp
Probably best to give them a call. I can't find anything either.
Couple things you can do though. Go to a hardware store and purchase nuts that have the anti-rotation crown on them, or you can use the nuts you have now and stick a flathead screwdriver between the nut and the housing so they won't rotate while you're tightening them.
Old Apr 17, 2015 | 09:40 AM
Leftcoaster's Avatar
Leftcoaster
Simple solution: push a flat blade screwdriver along side the head of the bolt (or nut, what ever is inside the slot on the muffler) to keep it from spinning. Works every time.
Old Apr 17, 2015 | 06:43 PM
dirtdobber's Avatar
dirtdobber
I keep small wooden wedges just for that.
You can wedge a screw driver sideways to hold it that way you shouldn't have to hold it.
Are your sure the thread isn't damaged?
If it's that hard to tighten something may be wrong. You can use a stove bolt if need be. Just get the right size.
Old Apr 17, 2015 | 09:36 PM
btsom's Avatar
btsom
Can't believe no one has suggested speed nuts. They are narrow U shaped gadgets that slip over the bracket that the bolt goes through. One side of the U has a hole bigger than the bolt and the other side has a threaded section for the bolt to screw into. The bottom of the U keeps the speed nut from rotating. They are available at hardware stores, home improvement stores and auto parts places, Oreilly's, Autozone etc. Take in the bolt you want to use so you can match size and thread pitch.
Obviously, the best solution is the factory hardware if they are supposed to include it with the pipes.
helluvanangel
Aug 27, 2021 09:55 PM
monster715
Mar 18, 2014 10:09 PM
Gambler72
Apr 28, 2010 06:21 PM
Gambler72
Apr 28, 2010 12:30 PM
skydiver55
Sep 21, 2008 09:00 PM
