Clutch cable torque tool question
Old Apr 25, 2015 | 10:36 PM
Dobe66's Avatar
Dobe66
Default Clutch cable torque tool question
About to install a new clutch cable and the manual gives a torque spec for the cable at the clutch release cover. If it were a wire I could understand the use of a socket with a slit cut in it. Since the cable is pretty stiff it doesn't seem like it could safely bend out of the way enough to put a torque wrench on the socket, even a long socket. It's a relatively low torque spec and, on the Barret cables, there is a warning about over-torque. How have you folks gone about this?
Old Apr 26, 2015 | 04:09 AM
Big Money's Avatar
Big Money
I just snug mine up good, nothing crazy you have a o-ring in there.
Old Apr 26, 2015 | 05:35 AM
Tracker56's Avatar
Tracker56
Try a crow's foot with the torque wrench. just remember that it is adding a little length to the handle so reduce your torque setting a bit.
Old Apr 26, 2015 | 06:13 AM
Buelligan666's Avatar
Buelligan666
You use a crow's foot at 90 degrees from the torque handle. Then it doesn't increase torque.
Old Apr 26, 2015 | 07:28 AM
SBates08's Avatar
SBates08
All it needs is to be just a little over hand tight. 3-5 ft-lbs. It'll be hard to gauge that with a torque wrench.
2010 Limited with some stuff
Old Apr 27, 2015 | 07:54 AM
Veekness's Avatar
Veekness
No need to get all picky with this one, as stated earlier, it's got an O-ring sealing it, so just snug enough is good enough...suggest some blue Loctite on the threads to keep it from backing off, just make certain the threads are dry...use a little carb choke cleaner and compressed air to get rid of the oil in the threads, if necessary.
Old Apr 27, 2015 | 09:31 AM
skydude426's Avatar
skydude426
I agree with you. If you want to torque it use a crows foot at a 90 degree angle to the torque wrench. A crows foot or other attachment at a 90 degree angle to the handle of the torque wrench won't change the accuracy of the torque setting.
Old Apr 27, 2015 | 09:47 PM
Dobe66's Avatar
Dobe66
Thanks for the help. Thing I'll just snug it up with some blue loctite and call it good. The crow's feet wrenches look handy so I might pick some up just to add to the tool kit.
Pothole914
Nov 13, 2016 08:04 AM
NAILIT RK
Mar 22, 2015 08:02 PM
R_W_B
Dec 9, 2010 04:12 PM
SoCalDyna
Apr 14, 2009 09:39 PM
4merRacer
Jan 31, 2008 02:15 PM
