Drive Pulley Interchangeability?
Old May 8, 2015 | 11:20 AM
lavid2002's Avatar
lavid2002
Stage II
Default Drive Pulley Interchangeability?
Hey everyone,
I just changed out the main gear on my '89 FLHTCU. Both the splines of the 5th gear and the drive pulley were damaged, so I'm hunting for a pulley now.
A lot of these sprockets for the FLHTC look like they are very similar, even interchangeable. Can anyone confirm or deny?
Thanks
-Dave
http://www.ebay.com/itm/04-Harley-To...eccfb3&vxp=mtr
http://www.ebay.com/itm/Harley-Late-...3D131028799411
Old May 8, 2015 | 11:37 AM
DanDman's Avatar
DanDman
'85-'06 pulley's will work. The '89 spacer and a new seal has to be used.
Old May 8, 2015 | 12:33 PM
lavid2002's Avatar
lavid2002
Stage II
Outstanding, I just ordered the '04 in the ebay link.
Thanks for the prompt reply, have a good one.
-Dave
Old May 8, 2015 | 02:18 PM
SBates08's Avatar
SBates08
I'm kinda in the same boat. Trying to figure out if a pulley from an 06 Heritage will fit the 07 SG rear wheel. I was told the 06 SG wheel would work on the Heritage but not certain about the 07 wheel. The 06 SG has a 70 tooth and the 07 SG changed to a 66 tooth and I'm not sure if the bolt pattern changed any. Anybody have any expertise on this???
2010 Limited with some stuff
Old May 8, 2015 | 02:52 PM
tfi racing's Avatar
tfi racing
The 06/07 rear wheel should be the same,I just put a 70t 1-1/8" pulley off a Dyna on my Airstrike wheel.08 is where the axle and spacers started to change,the pulley should be ok.
Old May 8, 2015 | 03:03 PM
SBates08's Avatar
SBates08
That's exactly my thoughts too but I couldn't confirm if the bolt patterns were the same. Finding a front wheel (Airstrike) in an 18" isn't too difficult. Finding the 06-07 rear has been a booger.
Old May 8, 2015 | 03:16 PM
DanDman's Avatar
DanDman
The bolt patterns & pulley center hub diameter are the same for '00-'07 Touring. Dynas, Softails, & Sportsters '00- current? Pulley differences are belt width, tooth count & offset.
Old May 8, 2015 | 04:05 PM
SBates08's Avatar
SBates08
Thanks Dan. I was thinking the same just needed reassuring.
Old May 8, 2015 | 07:01 PM
twistedcherokee's Avatar
twistedcherokee
I know that my 1999 & the 2005 SG wheel I needed to get a spacer with different hub centers. But I have a good friend that has a machine shop that hooked me up with what I needed.
Toby
jetmech74
Mar 4, 2015 12:15 PM
blackmopar
Apr 4, 2012 04:46 PM
HOGRIDA_06
Mar 2, 2009 01:35 PM
DyNaMc
Sep 28, 2007 07:28 AM
iclick
Mar 28, 2007 08:52 PM
