had to jump start bike this arvo after leaving ignition on dumb , riding down road and all of a sudden lost power nothing electrical working at all
any ideas nothing seemed wrong re battery was all hooked up no signs of fuses burnt out?
Can you jump it again?
First thing I'd do is charge the battery. While it's charging check the fuses again. Check the ground to the frame. Then I would hook a volt meter to the battery and watch the voltage while I hit the starter. If the voltage drops considerably the battery is toast.
Pull that battery out and have it load tested. Numerous auto parts house now do this.
How old is it?
As others have said, check the cable connections and also the integrity of the wires inside the insulation by feeling and slightly bending for "soft spots".
Sounds like you may have lost a ground or the battery has just given up the ghost....
