Road King headlight
Old Jun 9, 2016 | 12:12 AM
  #31
firefox23508's Avatar
firefox23508
Thanks for the info regarding the standard two light housing. Which bulb did you replace, the high or low beam bulb?
Old Jun 9, 2016 | 11:47 AM
  #32
dplantz's Avatar
dplantz
bikerlaw: I read this post and had no idea you can clean the insides of the old stock headlight. Did mine yesterday at lunch and it looks SOOO much better! thanks for the tip!
Old Jun 9, 2016 | 07:42 PM
  #33
bikerlaw's Avatar
bikerlaw
My bike has the single bulb. I was merely relaying information on bikes I have experience with. In the case of the current two bulb setups, like on the pre rushmore Limiteds, or the current Road Kings, they replaced BOTH the low and high (H9/H11) bulbs with LED's. Fuel Moto, DK Customs, and Eastern Performance sell the bulbs for under 100 bucks. I can attest, they are bright as FREEEEAK! Those buckets are awesome because when you hit the high beam (at least on the Gushmores), the low beam stays on as well. So your looking at two, really bright LED's. It's like POW!, Daylight!
Yeah, cleaning off the inside really makes a difference. I was told..... but can't prove, that the fogging is grease, of all things. I was "told" that the lenses fog up over time due to the grease the MOCO uses to protect the socket from corrosion, breaks down over time. And as it breaks down, it disperses and settles inside the lens, Fogging it up. Is it true or a wives tale, I don't know. But it makes as much sense as anything I have ever heard.
Roadrage1996
May 26, 2017 02:40 PM
Joeynotz
Mar 19, 2017 01:12 PM
plongson
2014-2024 Touring Models
Mar 25, 2016 01:31 PM
Flying Horse
Jan 11, 2016 12:23 PM
Falcon195
Jul 11, 2014 12:32 PM
