I'm looking for a wiring diagram for a 08 electra glide with a 96 inch. It turns over but no spark to either plug. Want to check the volts at the coil and the ohms just don't know the specs. I got 6.11 ohms on the coil itself. don't know if that's high or in spec. It's a stock coil as far as I know it's a friends bike. If I can find a diagram I check the crank position sensor too. I think that's the culprit but not sure.
