High idle
Old Apr 16, 2017 | 06:47 PM
trunomad's Avatar
trunomad
Default High idle
2008 ultra. Idleing at 1500 RPM when warm. Tried the switch on switch off 6 times trick but did'nt solve the problem. Also, I'm running FUEL PAK. Problem had been intermittent but now doing it all the time. Any ideas? Maybe dealer reflash?
Old Apr 16, 2017 | 07:39 PM
dawg's Avatar
dawg
Dealer had a flash download to fix this a few years back. Can try that. Can also try cleaning the air pressure sensor in the throttle body with a MAF sensor spray or the like.
Old Apr 17, 2017 | 11:37 AM
trunomad's Avatar
trunomad
I got it fixed. I removed the plug going into the throttle body and then I noticed 2wires going into the plug had some copper showing through the insulation. Taped them up, cleaned contacts, used some dielectric grease and now idleing at 1000 RPM.
freeman73
2014-2024 Touring Models
Aug 5, 2020 11:27 AM
TiRider
Oct 22, 2018 09:49 AM
scglide
Sep 15, 2013 03:46 PM
AFblacksheep
Nov 9, 2012 12:45 PM
BCguy
May 16, 2009 06:43 PM
